Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Oct 2019
    good day po mga master. tanong ko lng po san po ba nagpapa angat ng kotse? newbie lng po ako. may something kasi na tumama sa ilalim ng car, nung sinilip ko may nayupi ng mga metal parts. natatakot kasi ako baka vital parts yun. paguide naman po anong pwede kong gawin. salamat po mga master.
    Gasoline stations.
    Quote Originally Posted by darwinlsantos View Post
    dalhin sa nakaka-alam.
    usually, any decent mechanic can do that, even without a lift.
    you can also take a good picture of it, and post it here.
    Bring it to a repair shop specializing in underbody repair. Madami naman sila, posted naman sa shop "underbody specialist".
    Basta huwag ka pupunta sa Rapide at baka lumaki at dumami pa problema mo.
    Oct 2019
    update. so napaangat ko na sya. at eto po ang result ng carelessness ko. sakit sa puso mga master. paguide naman po how to fix. salamat mga masterimg_20200224_165117.jpgimg_20200224_155158.jpgimg_20200224_155254.jpg
    Dec 2019
    nag offroading ka ba ts? Bring it na lang sa underbody repair specialist.
    gosh! what did you hit.. a dragon's tooth? a small, directed-force landmine? a dud rocket?
    para rin kasing, nadulas yung kotse sa pagka-jack.
    i am not familiar with that underside.
    but by the pictures alone, it would seem, no other vital parts were damaged.
    my gut response is, "have it fixed by replacing the damaged parts. if that proves too difficult or expensive, have it pukpoked and/or weld-fixed, po. BUT determine first, if it is aluminum or iron. if it is aluminum, you're out of luck. few welders know how to weld aluminum.
    then have it painted, to prevent rusting.
    if that part is plastic, have it replaced or patched. it should not be that difficult.
    the plastic cover is missing (destroyed beyond glue-ing?). that might be more difficult to source. the surplus places in banawe and evangelista, siguro. but be prepared to pay thru the nose.
    errr... what car, po?
    good luck.
    Nov 2017
    sir eto po ba un naupi?
    Jan 2008
    Buti hindi sa engine or transmission tumusok yan.. pag dun malamang susuka ka talaga ng pera
    Nov 2017
    brake lines ata din malapit sa yupi ?
    Oct 2019
    Quote Originally Posted by LOLZ View Post
    master. yes po. pati yung nasa likod nya.
    Nov 2017
    mukhang structural (since high tensile strength metal gamit well atleast sa jazz ganon) mainam na iconsult sa underchassis shop or sa casa just to be sure.
    ^sa ilalim ng handbrake
    ano ba nandoon, mukhang FWD so no vital part natamaan?
    The damage seems a result of an accident. Like a jack that slipped what others said. This kind of damage is definitely not from road debris. Masyadong pinpoint eh.
    Anyway, beating the panel and welding should do the trick. Best to be done under to prevent dismantling of many parts.
    ano kaya itong part na ito naputol?
    looks like a heat shield or a guard for small stones and stuff.
    Feb 2020
    Mukhang may nirampahan na may bakal/tubong tumikwas pagtapat sa bandang ilalim lampas ng shifting assy. kaya nabutas/napunit yung mga tinamaan. Buti at wala nasugatan.
    Hanap na lang ng magaling na underchassis mech nearest you pra ma-estimate ang gastos. If d kaya ng latero at welding ang mga nasirang metal covers, marami mabiling replacement part/s sa Banawe if Japanese or Korean ang manufacturer. If European or USofA brand, swerte ang 1X month waiting time.
    Good luck!
    ^may dashcam footage ka?
    malamang di mo na nasingil, dahil di mo alam na malaki damage ?
    Oct 2019
    unfortunately wala. sa sobrang panick ko din di ko alam pano ako magrereact mejo blury din yung plate no. tska gabi. ang natatandaan ko lng na scene e yung may kumakalampag sa ilalim habang nagslowdown ako patabi sa gilid tas tumalsik yung cover sa ilalim ng handbrake. honda city 2016 po.
    Insulator ng transformer ang tumama sayo, malamang electric contractor ang truck na sinundan mo. Latero lang kelangan dyan since part ng frame ang nasira. Pwede mo din modify lagyan ng funnel na may takip para may instant trash can ka, or kung naiihi ka na derecho na dyan..hehe
underneath
