Results 1 to 10 of 10
    Mar 2003
    Anyone knows where I can find a computer replacement for Honda City '99 model, please let me know. Thanks.
    Also, if there are any auto shops that can fix/replace computer box for Honda City '99 model.
    Again, Thanks,
    erigby
    what's wrong with the computer box? nalubog ba sa baha?
    Mar 2003
    hindi naman siya nabaha. one time bigla na lang umilaw ang malfunction indicator tapos
    naging unstable na pag-idle (tumataas ang RPM). Dinala namin sa casa at ang sabi eh sira daw ang RACB (rotary air control valve) at ECU (computer). Sobrang mahal! Hindi ko pa pinapagalaw sa casa.
    Me alam ka bang puedeng mapg-gawang iba ?
    Hi guys,
    meron problem friend ko sa honda city 2000 type-Z 1.3 .. help naman po..thanks
    eto po yung kwento nya..
    Kapag pinasok mo yung key, normally yung engine indicator eh iilaw tapos mawawala na, kaso inde namamatay yung indicator ko.., so pag-start ko ng engine, ayaw nya mag-start unless mag-step ka sa gas... tapos kapag nabitawan mo yung gas mamatay na ulit yung engine o kaya pag nag-down gear ka na habang tumatakbo ka eh mamatay na din yung engine..
    Diagnosis of Honda Makati: problem daw sa rotary air control valve and repair ecu
    any other opinions?
    mga 19K yung ECU sa casa daw
    thanks
    Hello erigby & Revogsx
    please visit
    www.hondaclub.com.ph/forums
    there are a lot of gurus there that can help
    have you tried resetting your ECU? remove the negative battery terminal for 5 mins then re-install.
    hindi ko sure kung pwede mga surplus ECU galing japan sa city.
    40K daw pala yung ECU sa casa, 10K kung ire-repair yung ECU
    9K dun yung RACV
    wala pa yata labor cost nito..
    Try mo sa GreaseBee sa Ortigas Extension (lagpas ng junction), nagrerepair sila ng ECU...
    Mar 2004
    Get a second opinion from another casa, our car was previously diagnosed with the same problem. Had them check again properly since the ECUs are not that easily damaged unless they are submerged in water. It turns out that the technician did not plug the ECU firmly. Most ECUs are built to last a long time.
    Sep 2004
    Try mo check yung fuel filter. Looks like you don't have enough fuel pressure. Nagbabara kasi yan kung minsan before the required replacment especially pag madalas kang low on gas or running on reserve. Nahihigop yung dumi. Reset mo rin yung computer. Hope this helps
    salamat sa mga reply po ninyo
    paano nasisira ang Air Control Valve? dahil ba madumi na air filter? common problem ba ito sa honda? o lahat ng car meron nito?
HONDA CITY '99 COMPUTER
