Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Aug 2005
    hi guys,
    The halvoline energy blue has been phased out by caltex.. What would be a better substitute?
    btw, can I mix different brand as long as if has the same rating?
    Jun 2006
    Try Royal Purple 5w30 or 10w30. Its 100% synthetic oil. It gave me better FC compared to Havoline Energy.
    There is a thread about this oil. I belive the thread list the retailers. Just do a search.
    Castrol also has a 5W-30 blend that's also labeled as FC (fuel conserving).
    Am currently using Royal Purple 10W-30.
    Be careful though in using the 5W-30, not all engines can use that safely in the long run (check your car's manual for the recommended oil weight for our tropical climate).
    __________________
    bigbigcar.com Review: Hyundai Tucson 4x2 CRDi 2.0 A/T
    Quote Originally Posted by imperialv View Post
    hi guys,
    Oh nooooo! I'm due for an oil change pa naman! Ito ba yung nasa blue liter plastic containers labeled fully synthetic? I've been using this brand for some years now with good results. Can't remember if its 5-30w, is it? Can't seem to remember these numbers. Anyway, wala na ba nito?
    Nov 2003
    royal purple has the 30 wt viscosities readily available
    been a havoline energy user since nung semi-synthetic pa lang ito. hehehe.
    but due to the phaseout state nito, napilitan ako maghanap alternative. and good enough... found Royal Purple. same rating lang, 5w-30. and so far (2months using na) so good! try mo na lang din.
    Jun 2004
    Wala na bang mabibilan ng old stocks nito?
    Jun 2006
    are you sure na phaseout na ito? was in caltex slex this am. they were still selling it.
    Aug 2005
    Quote Originally Posted by userfriendly View Post
    mga old stock na yun.. dun din ako bumili ... actually mura ang per liter nila compared sa iba...
    how much ang royal ngayon, and where can I buy one?
    Jun 2006
    Royal Purple retails for around 440 pesos per liter. Contact Speedyfix for a retailer near you. His number is on his sig.
    Nov 2003
    leme know where you are so i can point you in the direction of the closest dealer
    talking about alternatives for the 5w-30 fully synth, would it be really bad for the engine if i chose to use 5w-50 fully synth? what would be the after effect?
    Aug 2005
    Quote Originally Posted by speedyfix View Post
    i'll get in touch with you soon.. kaka change oil ko lang and may 4 liters pa akong stock...
    thanks..
    Nov 2003
    between the 5w30 and 5w50 you will see a decrease in engine response and fuel economy due to the thicker viscosity.
    better to retain the 5w30 if that is what is recommended by the engine.
    imperialv, no problem bro
    Jun 2004
    Saang Caltex pa ang may old stock nito na malapit sa Makati or Quezon City area?
    5w-30? is gave me better FC on our trooper and its a Royal Purple ..
    baka meron pang havoline sa ace hardware ..
    Nov 2003
    s_quilicot, glad you're happy with the oil
    Jan 2008
    Important additives in the engine oils go stale. Recommended shelf life before use is 3yrs. Use RP na lang the price is fair enough. For optimum reliability use FS tranny oil na rin.
    Jun 2004
    Quote Originally Posted by youngrider View Post
    Ganoon ba. Unfortunately, Royal Purple doesn't have an oil with the correct rating for my engine (i.e. WSS-M2C913-B). My only two choices are Shell Helix F and Havoline Energy.
    Nov 2003
    in that case it's best talaga to use the oil that meets the engine requirements
Halvoline Energy 5-30w phaseout...
