Results 1 to 20 of 26
    Aug 2005
    hi guys,
    The halvoline energy blue has been phased out by caltex.. What would be a better substitute?
    btw, can I mix different brand as long as if has the same rating?
    Jun 2006
    Try Royal Purple 5w30 or 10w30. Its 100% synthetic oil. It gave me better FC compared to Havoline Energy.
    There is a thread about this oil. I belive the thread list the retailers. Just do a search.
    Castrol also has a 5W-30 blend that's also labeled as FC (fuel conserving).
    Am currently using Royal Purple 10W-30.
    Be careful though in using the 5W-30, not all engines can use that safely in the long run (check your car's manual for the recommended oil weight for our tropical climate).
    __________________
    bigbigcar.com Review: Hyundai Tucson 4x2 CRDi 2.0 A/T
    Quote Originally Posted by imperialv View Post
    hi guys,
    Oh nooooo! I'm due for an oil change pa naman! Ito ba yung nasa blue liter plastic containers labeled fully synthetic? I've been using this brand for some years now with good results. Can't remember if its 5-30w, is it? Can't seem to remember these numbers. Anyway, wala na ba nito?
    Nov 2003
    royal purple has the 30 wt viscosities readily available
    been a havoline energy user since nung semi-synthetic pa lang ito. hehehe.
    but due to the phaseout state nito, napilitan ako maghanap alternative. and good enough... found Royal Purple. same rating lang, 5w-30. and so far (2months using na) so good! try mo na lang din.
    Jun 2004
    Wala na bang mabibilan ng old stocks nito?
    Jun 2006
    are you sure na phaseout na ito? was in caltex slex this am. they were still selling it.
    Aug 2005
    Quote Originally Posted by userfriendly View Post
    mga old stock na yun.. dun din ako bumili ... actually mura ang per liter nila compared sa iba...
    how much ang royal ngayon, and where can I buy one?
    Jun 2006
    Royal Purple retails for around 440 pesos per liter. Contact Speedyfix for a retailer near you. His number is on his sig.
    Jun 2004
    Paano pumunta diyan sa Caltex SLEX galing sa Makati?
    Jun 2006
    Biggs,
    Just go to south super highway. There are 2 Caltex stations there. They are right on the highway. One is south bound after Petron near Mamplasan exit. The other one north bound, is right across Petron. Was here yesterday, may nakita pa ko.
    You need to pay toll fees. Better look around near your place first.
Halvoline Energy 5-30w phaseout...
