queston naman,
- Mahirap kasing ipasok sa pirmera yung cambio, pero yung segunda pataas medyo oks naman po.
- need bang pa inittin muna engine bago palakarin? medyo namamatayan ako eh, gawaain ko kasi, pasok sa kotse at paandarin/lakad na agad.
- san ba magandang mag pa change oil, drain ng radiator, etc. last pakasin napasok sa casa to noong 60T-Km pa sya eh, now its 67T- km na. san ba marerecomenda nyong shop at anong mga dapat pacheck?
bro have it checked in speedyfix. the proprietor is a regular fixture here so better consult him w/ your probs for a more thorough answer. i hear his shop is along shaw blvd near pure gold. search mo na lang siya for his contact numbers
regarding your difficulty in shifting gears, most likely a change in manual transmission fluid is in order for you. i had the same prob w/ a car similar to yours and my gear shifting smoothened out after undertaking this maintenance procedure. ngayon swabeng-swabe na siya
iyong iba mong maintenance probs kay speedyfix mo na lang tanongin kasi alam niya ang kinakailangan gawin pag dating sa ganyan
Ganyan dati problema ride ko. Needed to replace the clutch cable. Pinipilit ko i-shift from primera kasi matigas, ayun naputol. buti nalang nasa bahay nako.
Kung palit lang ng gear oil, any gas station with a lube bay & lifter can do it. Labor would be around ~200. Yung gear oil would cost anywhere from 150 to 600/liter (fully synthetic).
pansin ko di naman talaga mahirap pumasok ng primera eh,
and siste lang pag galing ako ng 3rd or 4th tapos medyo menor ng konti para lumiko at gusto ko sa nga ipasok sa primera medyo mahirap, kaya segunda na lang naipapasok. =)
sori po medyo baguhan pa lang sa driving...
tama po ba na dapat kung galing ka ng 4th or 5th,
pag mag breabreak ka na dapat daanan mo ng pabab yung lahat ng gear kesa mag neutral ka na lang at hantayin yung pag bagal ng car?
you don't shift to first gear when downshifting and the car is still in motion... masisira gears ng tranny mo nyan... when negotiating a turn or humps you downshift to 2nd gear not first gear...
unless nag full stop ka tsaka ka pa lang lipat sa first gear.
