Results 1 to 12 of 12
    Sep 2006
    queston naman,
    - Mahirap kasing ipasok sa pirmera yung cambio, pero yung segunda pataas medyo oks naman po.
    - need bang pa inittin muna engine bago palakarin? medyo namamatayan ako eh, gawaain ko kasi, pasok sa kotse at paandarin/lakad na agad.
    - san ba magandang mag pa change oil, drain ng radiator, etc. last pakasin napasok sa casa to noong 60T-Km pa sya eh, now its 67T- km na. san ba marerecomenda nyong shop at anong mga dapat pacheck?
    many thankz
    nianz
    ChrisAniano = Skype Nick
    bro have it checked in speedyfix. the proprietor is a regular fixture here so better consult him w/ your probs for a more thorough answer. i hear his shop is along shaw blvd near pure gold. search mo na lang siya for his contact numbers
    regarding your difficulty in shifting gears, most likely a change in manual transmission fluid is in order for you. i had the same prob w/ a car similar to yours and my gear shifting smoothened out after undertaking this maintenance procedure. ngayon swabeng-swabe na siya
    iyong iba mong maintenance probs kay speedyfix mo na lang tanongin kasi alam niya ang kinakailangan gawin pag dating sa ganyan
    hth
    Sep 2006
    salamat sa reply pre,
    mga magkano kaya?
    any ways nick yan ba talaga yung speedyfix?
    sorry wala akong idea kung magkakano aabutin eh
    iyan talaga nic niya dito bro
    Oct 2003
    Ganyan dati problema ride ko. Needed to replace the clutch cable. Pinipilit ko i-shift from primera kasi matigas, ayun naputol. buti nalang nasa bahay nako.
    also try to check your gear oil.
    Sep 2004
    Kung palit lang ng gear oil, any gas station with a lube bay & lifter can do it. Labor would be around ~200. Yung gear oil would cost anywhere from 150 to 600/liter (fully synthetic).
    Sep 2006
    mga gano kaya katagal (oras) pag gawa rito?
    May 2005
    pagpalit ng gear oil sandali lang iyan ,wala pa isang oras cguro iyan
    (wag lang may nauna pa sa iyo na customer) sa mga shop
    kaya lang baka meron pa ibang problem ang tranny/clutch mo
    kaya dapat wag mo madaliin ang pag paparepair
    di bale na matagalan basta cgurado ang work
    Sep 2006
    pansin ko di naman talaga mahirap pumasok ng primera eh,
    and siste lang pag galing ako ng 3rd or 4th tapos medyo menor ng konti para lumiko at gusto ko sa nga ipasok sa primera medyo mahirap, kaya segunda na lang naipapasok. =)
    sori po medyo baguhan pa lang sa driving...
    tama po ba na dapat kung galing ka ng 4th or 5th,
    pag mag breabreak ka na dapat daanan mo ng pabab yung lahat ng gear kesa mag neutral ka na lang at hantayin yung pag bagal ng car?
    tip naman po dyan.
    Jan 2003
    you don't shift to first gear when downshifting and the car is still in motion... masisira gears ng tranny mo nyan... when negotiating a turn or humps you downshift to 2nd gear not first gear...
    unless nag full stop ka tsaka ka pa lang lipat sa first gear.
    Nov 2003
    i agree with impulzz pero if it's from a start then dapat madali lang ipasok yan. replacing the gear oil will probably help.
    wala naman clutch cable yung civic so that will not be the problem.
Help : Civic 96 Vtec - Primera problem
