malamang na stucked up na ang brake wheel cylinder,or ayaw ma-release ang hand brake. best thing to do is remove the tire, remove the brake drum or caliper assembly (which ever is applicable to your ride) and try to turn the
axel assembly by hand. It should turn easily without the brake drum or caliper.
If not, then you have a stucked up wheel bearing.
