Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
    May 2004
    maybe isa lang ang nagstuck. yung isang gulong e working pa. malamang stuck break nga yan dahil kakarelease mo lang ng handbreak. bubuksan yung brake drum mo nyan for sure. ordinary mechanic can handle it.
    bro, baka natakot yun gulong sa avatar mo? hehehheehe joke lang...
    Sep 2006
    ramdam ko isang gulong lang stuck e... sana maawa ung mekaniko sa avatar ko
    Jun 2006
    Paayos mo agad and dont drive that car if possible. Your brakes are most likely stuck up. Your brakes will overheat and it will not take long before it starts to smell like burnt rubber. You will also lose brake pressure. Your brake pedal will sink and you will have to pump the brakes to get any resistance.
    Sep 2006
    if my brakes are indeed stucked... are there any parts which needs to be replaced? I only drove for 200 meters.. binagalan ko rin ung takbo para di masyado uminit
    May 2007
    Quote Originally Posted by MasterZerg View Post
    Your piston brake caliper ay sira na kaya nag stucked up. You could buy a overhaul brake caliper kit usually spring and rubber gromet and rubber boot. Isang set yan for both axle. Madaling gawin yan basta bit mechanical person ka. Bumili ka narin ang bagong brake fluid mo to replace those old contaminated fluid in your brake system.
    Nov 2003
    sa esi you have a drum at the back... could be a stuck shoe caused by kalawang if you passed by a flood. have it opened immediately and replace the necessary parts.
    Mar 2005
    na-try mo na ba iatras
    Sep 2006
    i already tried reverse pero ganon pa rin...
    hinde kaya sir, matagal hinde nagamit yung oto na naiwan na naka handbrake? normally kung stuck up lang, pag pinilit mo i andar tutunog at maiikot mo ulit , pero kung maiikot then stuck ulet, pabuksan mo na para sigurado, baka kinalawang sa mga pagbahabaha.
Help! Ayaw umikot isang gulong ko
