Results 1 to 10 of 13
- Nov 2002
- 179
November 16th, 2002 10:16 PM #1can a 2000 city...with a 1.3 non-vtec engine's head be swapped with a d16's head? giving the 1.3 engine vtec? is this possible?
coz i've been reading in the net that d16's heads can be swapped with b18's heads...so i was thinking if this would be possible in my case.
thanx.
November 17th, 2002 01:10 AM #2
WHAT? :shock: D16 kasya sa B18? are you serious?
Anyway.... why would you put a VTEC Head onto a D13? Change the whole engine na lang. :D
November 17th, 2002 01:12 AM #3
chase...change the car.herhehrehr
kidding..
engine nalang...kung pwede man yan...marami pang ka ek ekan kailangan gawin...hassle..
- Nov 2002
- 179
November 17th, 2002 05:36 PM #4nakakatuwa kasing kumalikot ng makina e...kaya nag tatanong ako kung pwede =)
sure ako ng kasya ang b18 head sa b16/d16.
now i just wanna know kung pwede yung b16/d16 head sa d13 =)
mahal mag swap e..tsaka mas problematic...at least dito, pin pointed mo na agad kung magkaproblema man kung san galing yung problema...
alang pera magpalit ng kotse =)
November 17th, 2002 08:03 PM #5
ewan ko kung possible ang D16 sa D13 pero since pareho D series engine sila na SOHC baka pwede.
As for B18 to D16.... di pwede yun. DOHC head idikit mo sa SOHC block.... nope... hindi pwede
November 20th, 2002 12:07 PM #6
chase:::
im a bit rusty on honda engines but as far as i recall, malayo ang bore diameter ng B engine sa D engine... hindi kaya ng machine shop without compromising reliability.
Regarding your head swap. Pwede yon, kaya lang, ibababa mo yung block mo para ma-check kung may sabit and sabay ayusin. The head swap is feasible coz all D series engines have the same Bore. Stroke lang nagkaiba. As Glenn pointed out, di porque kinabitan mo Ng VTEc head ay ok na yon. VTEC is hydraulic, but is actuated by electronics. Believe me, mas mahihirapan pa yung magkakabit if you swap the head that just changing the whole engine.
Sa head swap puro modified wirings and modified everything, sa engine swap, almost stock karamihan.... Expensive but less ang sakit ng ulo.
my 2cents :D
Let me tell you a story.... theres this guy who wasnt satisfied with his D12B engine on his civic hatch. What he did was get a surplus D15 engine with dual carbs..... swapped the innards..... he was still not happy.
After a lot of OVertime at the office, he ponied up some cash and put a B16A in his hatch...... then he became happy :D
November 1st, 2006 11:16 PM #9
hi.. im planning to swap my d15 non vtec carb type to a b16 or d15 fuel injected vtec engine. could you help me out where i can find those engines and i have no idea how much it will cost me and is it unlikely change the whole thing including transmission or just the engine itself? i dnt know if the transmissions are compatible with each other..
thanks a lot..
November 1st, 2006 11:53 PM #10
shop around banawe or evangelista. mahal ng B16 ngayon. some say mga 80-90k for the engine only. D15 mura lang, mga 25-30k. prices dont include install pa.
high idle RPM at engine start
