Results 1 to 10 of 10
December 6th, 2007 10:57 AM #1
my car is an '06 honda city cvt. minsan kasi ayaw magstart yung car ko eh. i dont know if my alarm (autopage) is causing my problem. the autopage kasi may starter cut-off eh. initially i was wondering kung dat was the problem baka kasi nagloloko pero i had the starter cut-off relay checked sa blue lazer (distributor ng autopage) ok naman daw.
no click whatsoever pero ok naman yung battery (i just change this like 3 months ago)
i also had honda q ave check my electrical system. ok naman daw lahat.
pag ayaw magstart normally, i do the shift lock maneuver just to start the car, but sometimes that doesn't even work. pero after a while magstart na ulit siya. minsan naman i just turn the key and mmya bigla na lang siya magstastart after a long delay.
could it be my starter?
i'm running out of ideas na kung ano yung problema.
help please?
December 6th, 2007 01:12 PM #4
tama si bro mazinger z, try to get a 2nd opinion in another casa. baka matumbok din ang problema niyan
December 6th, 2007 06:01 PM #5
Pwede rin yung starter solenoid. Pero bago pa kasi car mo eh...hmmm...
Dun sa Accord ko kasi, akala ko rin yung starter kill ng Clifford alarm ko, kasi ni click wala. Nakalagay naman sa P or N yung selector ng tranny. Nung binaba yung starter, akala ko brush pero starter solenoid lang pala.
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 9th, 2007 08:39 PM #6if it's an 06 model then you're under warranty pa. bring it to your dealer.
December 9th, 2007 09:37 PM #7
Long shot: Check the battery terminal if dirty, clean if needed, then really thighten the terminals. I've seen starting problems occur even with a fairly tight terminal, but simply further tightening did the trick.
December 13th, 2007 01:39 AM #8
[SIZE="5"]oo nga. check the battery terminal. nangyari n sakin yan dati. pina check ko starter, glowplugs, elec system.. wala naman problema...
tapos isang araw nagpa gas ako.. edi syempre u turn off before re filling.. tapos nun tapos na ma refill ayaw mag start!!!.. nakakahiya sa likod ko na kotse nakapila magpapa gas... ang ginawa ko binaba ko handbrake ko tapos mejo umabante tapos tinulak ko na.. tapos tinanggal ko battery terminal then linis tapos kabit ulit.... ayaw pa rin, sabi ng gasoline boy "sir basain nyo po".. ayun binasa ko tapos 1 click lang nag start na kaagad..
ang ginawa ko ngayon pagkauwi ko, tinanggal ko battery terminals ko + and -... ang ginawa ko sa ulo ng battery mismo ay niliha ko tapos kinudkod ko ng pang steel na lagare (ung kulay blue) para magkaroon ng ngipin na maliliit yung terminal,,
after ng mahabang panahon.. di n nangyari sakin yung nangyaring kahihiyan sakin sa gas station na after mag pa gas ay ayaw mag start..
ganun lang pala.. lagyan ng ngipin yung terminal na battery, ung ulo na kulay silver..
1 click na lang...[/SIZE]
December 13th, 2007 10:03 AM #9
I think I used to have that problem kapag turn ng key walang redondo, pero okay naman charging system, battery and starter.
I remember my mechanic friend put a relay between the battery and an electric wire leading to the engine (can't remember exactly where it leads to) after that okay na.
HTH
December 13th, 2007 07:17 PM #10
nangyari na din sakin yung ganyan. tiningnan kong lahat ng electrical pati alarm. Ang culprit pala ay lumuwag yung turnilyo ng body ground ko.
Xiaomi E-Car
