Results 1 to 10 of 10
    Dec 2004
    before step lang ako ng 2 times sa gas then ok na
    ngayon kailangan ko pang apakan ng konti ang gas para lang di mamatay ang makina.
    the ff items were already checked:
    - battery
    - starter nilinis
    - spark plug nilinis din (malinis ung tip ng spark plug walang oil)
    - alternator charging is ok
    - timing was adjusted (sabi ng mechanic naka advance ang timing so binago niya)
    - air filter di pa naman madumi pero nilinis na rin
    ano pa kaya ang problem? or dapat i check pa? TIA.
    Quote Originally Posted by nim ra
    - battery
    - starter nilinis
    Check mo rin fuel filter.
    Dec 2004
    my ride is a corolla xl 92 carb. forgot to mention the fuel filter is also clean.
    sabihin mo sa mech. mo check niya ang choke at base idle nung carb mo ,baka kapos sa gas
    Aug 2005
    pre.. nag change oil kna ba? nag pa change kna ba ng air filter? ngk ba gamit mo spark plugs? the oil filter is new ba? lets make it sure its all new.
    I have the same problem, pero '00 XL Corolla. Carb pa din ata yun....
    Aug 2005
    2000? di ko alam carb pa din iyun..
    all 1.3 2E engined corolla is carb pa, check mo din mga vacuum lines ng carb, baka brittle na or may leak, or overhaul na din ng carb. or kung may auto choke, baka non-functioning na, pati high tension wires pa check mo din for resistance. dami factors kse na possible
    May 2005
    Got this from an article Dude hope it will somehow help
    Carburetors have two 'enrichment' systems.
    1) The OBVIOUS choke air flap that is plainly visible in the primary carb
    throat. This needs to close fully when the engine is COLD after the
    throttle has been depressed and released once. As the engine cranks over,
    manifold vacuum develops which activates a vacuum diaphragm whose purpose is
    to pull open the choke a small / moderate amount.
    2) The Accelerator Pump. This circuit operates in sync with the primary
    throttle. With a flashlight, engine OFF, look down the primary carb throat
    and operate the throttle a couple of times. The Accelerator Pump will shoot
    a small stream of gasoline down the carb throat each time as you open the
    throttle. This feature is utilized to "prime" a cold engine for starting as
    well as its normal function of compensating for momentary lean mixtures
    brought about by sudden throttle openings.
    Suggest investigating the accelerator pump operation.
    sira na siguro ang auto-choke sa carb mo.
    you can use the manual choke switch inside your car by pulling it halfway before starting your engine. tapos kapag warmed up na ang engine, you may turn it off na.
Hard starting sa umaga
