Results 1 to 9 of 9
- Aug 2003
- 9,720
May 1st, 2008 12:03 PM #1hi all,
i've noticed this a couple of times na. pag paalis na ako whenever i stop over at a mall or supermarket, parang nahihirapang magstart ung makina. nangyayari lang to when it's just a quick stop(less than 1 hour), pero pag medyo matagal parang normal naman.
- Nov 2006
- 299
May 1st, 2008 01:05 PM #2sana kompletuhin nyo naman yung post nyo kasama na dito yung brand ng kotse,year model,etc.
- Aug 2003
- 9,720
- Nov 2004
- 141
May 1st, 2008 07:43 PM #5when do you experience the problem ? have you driven a good distance prior to stopping over the mall ? whre are you parked when you have this problem ?
- Aug 2003
- 9,720
May 1st, 2008 08:03 PM #6mga 15-17km ung naitakbo ko, then i parked at the open parking space. wala namang incline or anything
- Jan 2008
- 4,726
May 1st, 2008 10:47 PM #7have your engine oil changed immediately... happened to me before everytime i run the vehicle then stop turn-off engine for 5 mins then pag start ulet parang hirap na sya pero nag start naman.. i changed my oil yun mas maganda at special ayun solved na problem.. lumalabnaw kasi ng husto yung oil especially pag mainit na engine.. when you turn off your engine it will accumulate heat since the fans and water pump for cooling are turned off so yung oil will absorb the heat and lower its viscosity and your engine block / cylinders will expand making the engine hard to start (initial cranking)
May 1st, 2008 11:52 PM #8
Your problem is relatively your fuel pump relay. Test your car fuel pump after long hours of parking and listen carefully when turning on the ignition key to see if hear the fuel pump running, it's in the gas tank. So listen there for a humming noise. If you hear NO HUMMING but eventually starts and runs fine, then REPLACE the FUEL PUMP RELAY.
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 4th, 2008 05:46 PM #9i dubt your oil has anything to do with it. keep looking or have your mechanic troubleshoot the engine.
Suzuki JIMNY [merged threads]
