Results 1 to 4 of 4
- Oct 2008
- 469
August 17th, 2009 10:40 PM #1When I reach Fifth gear then downshifting to 4th gear, then I stepped up on Gas pedal, my gas pedal is locking, so what I do is, to push hard the gas pedal to release it again. Naglolock ang gas pedal ko during high speed? What is the cause??
August 18th, 2009 05:27 AM #2
joseph,
looks like you gained a free cruise control that's dangerous hehehehehe! the problem lies in the linkage being stuck maybe due to some mechanical binding or lack of lubrication. in most cases, the throttle control is returned to near close throttle by of course the return spring. tah dah! in older cars, for some of you who tinkered with the 60' or 70's cars, they were equipped with a step type idle speed cam and a dashpot. these components after a while prevents the throttle plate to return to idle speed maybe due to a broken you guessed right, a return spring. check the cables too if it is operated by cable and lubricate the cable inside of the tube.
jick
- Oct 2008
- 469
August 18th, 2009 10:02 AM #3joseph,
jick
August 18th, 2009 03:28 PM #4
Why do you want it removed? Sa Sport version ba ito?
2023 Ford Everest Owners Thread
