Results 1 to 10 of 11
    May 2005
    Quote Originally Posted by speedyfix View Post
    it's the throttle body. follow the air filter towards the engine and you should find it.
    speedyfix and co., thanks for the tip. Sprayed some oil and cleaned it with cloth. Pedal now as soft as before. Yes, it was due to some build-up at the cable. Problem solved, thanks to tsikot! Btw, I just saved P810 from labor with Ford. I asked them how much it will cost me and they said its P810.
    One last shot, on the odometer where you see the P,R,N,D,1,2.....
    All gears are easily engaged with a square surrounding the gear indicator except for N. It engages in N but the square is hard to appear. Sometimes, I just move the shifter from D to P then back to N or I just move the shifter up and down just for some motion and the square will appear. Any thoughts?
    Nov 2003
    great you fixed it!
    the problem with the light could be a busted gauge bulb or loose connections behing the cluster. hard to know what exactly without removing the gauge cluster.
Gas pedal hard on first 5 minutes!
