mga sir, normal po ba na mabawasn ang tubig ng reservoir for as long as 9km trip only. thanks in advanced sa mga mag re reply
carlo
carlo
check mo lang sir na hindi kumukulo yung nasa reservoir at hindi rin nagbabawas tubig sa radiator, kung overfilled yung reservoir normal lang na magbawas
lagi ka bang nag top-up ng tubig?..if that's the case then it's not normal....check for leaks...
sir, top up po lagi, under observation po ksi yung oto ko, before po ksi nag overheat yung oto ko, sbi po nila Blown head gasket, pero pina linis ko po muna yung radiator, nkita nung nag lilinis na barado na yung mga butas. so ngayon po obserb pa ako kung mag oover heat na naman. ang napapasin ko lang po mga 9kms lang po na takbo nababawasan na yung sa reservoir. kaya may question is; is it normal or not?
thanks in advanced
carlo
it is not normal the water on th reservoir becomes empty, for my experience pls check all your hose's, aircon fan, auxiliary fan if they are working and you mentioned that your radiator has been already overhauled /cleaned. If all are ok on what i mentioned and still your reservoir and radiator loses water my advice to replace your cylinder head gasket. To avoid other engines parts to be worn-out... gudlock
check first if there is no problem with radiator cap, usually its the cap that no sealed well and evaporates all water of reservoir
