Results 21 to 31 of 31
Threaded View
    consider these:
    car is galant vr v6
    changed spark plugs to platinum
    replaced leaking spark plug oil seals
    changed oil to semi synthetic
    replaced fouled high tension wire
    cleaned the "entrance" of the throttle body
    cleaned the sludge inside the valve cover
    cleaned the air filter
    cleaned MAF sensor (binugahan lang ng konting pressure ng hangin yung dinadaanan ng hangin)
    replaced oil filter
    replaced fuel filter
    used unleaded
    shifted to xcs(petron)
    shifted to super premium (shell)
    and still, sinisnok pag malamig pa ang makina.i thought the throttle body was just dirty...so we cleaned the entrance.should we dismount the whole thing and clean it?the mechanic said na biritin ko lang nang biritin para mawala yung dumi..ive been making birit ever since...nagiging ok siya.pero pag lumamig nanaman ang makina...ayun nanaman...*hiccup* *hiccup*
    pero pag mainit na ang makina. ok na ang takbo niya..swabe na.
    ano ba yung mga lines sa ibabaw ng throttle body?possible kaya na magbara ang mga yun?
    ano pa ba ang dapat kong linisin?
    haay haay haay
    thanks in advance
galant vr v6- "sinisinok"
