Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    consider these:
    car is galant vr v6
    changed spark plugs to platinum
    replaced leaking spark plug oil seals
    changed oil to semi synthetic
    replaced fouled high tension wire
    cleaned the "entrance" of the throttle body
    cleaned the sludge inside the valve cover
    cleaned the air filter
    cleaned MAF sensor (binugahan lang ng konting pressure ng hangin yung dinadaanan ng hangin)
    replaced oil filter
    replaced fuel filter
    used unleaded
    shifted to xcs(petron)
    shifted to super premium (shell)
    and still, sinisnok pag malamig pa ang makina.i thought the throttle body was just dirty...so we cleaned the entrance.should we dismount the whole thing and clean it?the mechanic said na biritin ko lang nang biritin para mawala yung dumi..ive been making birit ever since...nagiging ok siya.pero pag lumamig nanaman ang makina...ayun nanaman...*hiccup* *hiccup*
    pero pag mainit na ang makina. ok na ang takbo niya..swabe na.
    ano ba yung mga lines sa ibabaw ng throttle body?possible kaya na magbara ang mga yun?
    ano pa ba ang dapat kong linisin?
    haay haay haay
    thanks in advance
    parang ganyan din yata ang nangyari sa vrv6 namin dati. pa-check mo mabuti yung mga high tension cables kung meron leak, kung ok lahat, baka yung parang distributor na ang may tama (ano bang tawag dito? wala kasing distributor ang vr, ito yung parang pinalit na sa distributor, basta parang rectangular block sya).
    Signature
    ohhh...panong pag check ang kailangan gawin?pag mainit na..chaka naging ok ang sayo?
    pinalitan mo ba?how imuch damage?
    meron yatang equipment to check kung meron leakage yung high tension wires. makikita mong meron lumalabas na spark sa insulation.
    actually, nagkamali yung casa sa pagdiagnose nung una. pinalitan nila agad yung parang 'distributor', around 4K+ dati yun (1994-95). pero the next morning, bumalik yung sakit so balik din ako sa casa. dun palang nila na-check na meron leak yung high tension wire, yung shortest yung may leak. e kelangan daw buong set ng high tension wires ang bibilhin dahil wala daw tingi nun, e 7 pcs yun tapos yung shortest lang ang may problema kaya nagreklamo ako. nagkamali na nga sila sa pagdiagnose! ang ginawa nung mechanic, kumuha nalang sya ng high tension wire sa another vr dun na meron front collission. yun ang ikinabit sa akin. buti nalang hindi pa nila naitatapon yung lumang part ko. ni-refund nila yung bayad ko sa part, tapos hindi na ako pinagbayad dun sa high tension wire.
    Signature
    Uhm... have your tried putting Biodiesel? Hehehe :P
    Have you tried asking the opinion of some Mitsu mechanics? I checked yung sa VR ng Tito ko but it doesnt seem to manifest the problem.
    Some other things to consider:
    - vacuum leaks
    - a sensor that needs replacement (i'm not familiar with Mitsus but there might be other sensors that need to be checked)... is there any diagnostic tool that can do this?
    - try a HT wire from a VR thats running ok.
    nung nagpalit ka to platinums... dun ba nagsimula? or before pa?
    the weird thing kasi is....it gets better as the car warms up.
    nawawala din naman pag mainit na eh....we were thinking na kung sira talaga ang HT wires..kung may na hugot na tubes...continuous ang pag hiccup niya kahit mainit na ang makina...
    so i was thinking..something's clogged pag lumalamig..tapos nawawala pag mainit na...
    mazda....that i am not so sure.kasi pagkakuha ko, mainit na yung makina..tapos pag uwi ko, tune up agad.
    baka mismatch yung spark plugs sa engine... check mo... baka rin cold plugs ang naka kabit... or try mong lagyan ng stock spark plugs...
    subukan ko ibalik yung stock spark plugs...pero grabe ang hassle kasi gawin...tanggal pa intake manifold..etc...haaay haay haay
    Quote Originally Posted by GlennSter
    yep, kaya maraming mekaniko umiiwas dyan sa oto na yan pag dating sa tune-up
    V6 ka pa ha!!!! :bwahaha:
    Dec 2003
    dbale na mahirap naka-v6 naman tayo e hahaha
    Quote Originally Posted by ssaloon
    namu!!!yabang!
    deym..im really suspecting na the platinum plugs...will check the vacuum hoses narin
    Mar 2004
    Fuel accumulator? If there is one in the VR.
    happened to the SIR of my friend before, changed to split fire wires may konting miss during idle, changed back to orig nawala ng konti. changed the plugs to stock ngk from iridiums nawala lahat.
    Feb 2005
    Medyo OT lang po. Is the Mitsu Galant Gen 7 really an unreliable car? I'm planning on buying the galant being sold by someone in mymitsuph I've seen the car and even went on a spin with it and everything looks to be ok. I've already informed my brother on the purchase and he got mad at me. He told me that those kinds of Galants are unreliable and you're just wasting my money (sorry if I'm hurting anyone's feelings) because his friend came from a camry and sold it and got a gen 7 galant. And from what he observed is that the car is "sakit sa ulo" and he suggested that I should just get a camry. Now, I really like the car that I'm getting but I would like to hear some feedbacks on those who own those kind of Galants.
    Thanks again!
    Dec 2003
    afaik only the automatic 7G galants were problematic
    Quote Originally Posted by BlueBimmer
    a lot of people say that
    Aug 2003
    mahal daw yung front suspension bits ng galant pag nasira...
    Feb 2005
    Yeah, it was informed to me by the seller that automatic galants are problematic (di raw kaya ng tranmission yung power ng makina) and also the front suspension. Manual po yung kukunin kong VR. Would anyone know the going rate for these kind of model?
galant vr v6- "sinisinok"
