Results 1 to 4 of 4
September 10th, 2005 02:42 PM #3
Around 850rpm more or less.
Don't forget to disconnect the TPS (throttle position sensor) when setting the base idle.
What i do is I have my friend at the Nissan CASA adjust the idle using the CONSULT II computer. This gets the accurate reading of the RPM as there are usually discrepancies if you're basing it on the reading of the tachometer solely. TO give an example, i had it set at 850rpm per the CONSULT readout but the tach already indicates around 900+rpm.
September 13th, 2005 07:23 AM #4
thanks vinj. My friend bought this sentra and I found out that the tach reading is around 1000 rpm with A/C off and 1200 with it on. Advice him to take to the casa to adjus the rpm to specs and also to have a tune up. Iba kasi pag hi-tech mahirap sa tabi-tabi na mechanic. thanks again.
suggestion. you might try the local sarplas shops. the items will probably be painted in the color...
