Results 1 to 8 of 8
- Sep 2005
- 40
October 7th, 2005 01:54 PM #1Mga sirs,
help please!
What's the dfference between these? mercon, dexron, atf+, mopar and alison ----requirements?
Which is best suitable for w4a32 mitsubishi transaxle maliban sa diaqueen atf
of mitsubishi.?
thanks po in advance.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 10th, 2005 11:59 PM #2look at your car manual. it will have the recommended lubricant that you should put.
- Sep 2005
- 40
October 11th, 2005 10:05 AM #3sir speedy,
sorry but i don't have the manual for it is a subic vehicle.what atf will you recommend for the mitsubishi w4a32 transmission.If i'm not wrong this transmission is also used in awd eclipse and galant.
Need your advise sir...
thanks in advance po
October 11th, 2005 01:36 PM #4
commonly used ng mga japanese cars is DEXRONII.. nagka-delica ako noon, un ung nilalagay ko...so as sa liteace ko ngayon..pero ung liteace ko, bukod sa nakasulat sa drainplug ang fluid specs, pati sa dip-stick..
i think ung "diaqueen" ng mitsubishi is the brand ng ATF, dapat binasa mo ung label nung ATF..
- Sep 2005
- 40
October 11th, 2005 05:10 PM #5Ayummy,
diaqueen ang nrecomend ng casa,pero kelangan ko parin mga inputs d2 sa tsikot.Next month ko pa naman balak mag palit.
sir anong brand ng dexron II ang ginagamit mo? ok daw sana ung amsoil pero di pa ata available d2 sa pinas.
October 11th, 2005 05:41 PM #6
di ko particular sa brand..basta meets the specified specification, its fine by me..
i used "autolube" US oil repakaged in malaysia... red bottle cost 80 pesos per liter.
- Nov 2003
- 3,849
October 11th, 2005 11:34 PM #7for the most part, as long as it is a certain dextron rating then that's good enough regardless of the brand.
- Sep 2005
- 40
October 13th, 2005 08:33 AM #8Speedy & Ayummy,
Thanks very much for the nfo sir.It will be a great help.....
Daming issue ng SU7:grin:
Xiaomi E-Car
