mga peeps, what can u say about dunlop le mans? maingay b to? maganda b takbo n2? tnx a bunch kc parang matigas ang ride ko... 26 psi lng ang hangin ko s gulong tnx.....my tire is 195/55/r15 dunlop le mans ty a lot
Alin pong Dunlop Lemans? Madami pong models sa Lemans line up. hehehehe. 701, 702, RV, etc.
le mans are typically not performance oriented. they provide a good ride at the expense of some performance. i wnder why they are riding hard. technically the optimal pressure is between 28-30 so running it at 26 will make both tire wear and gasoline consumption suffer.
ok naman lemans, 702 ko before sa vti ok sya, but now i prefer falken ziex mas ok ride kahit mas xpensive. im referring to 17 inchers nga pala.
hindi naman ganoon ka harsh ang ride sa dunlop lemans 701(old model) ganito ang gamit namin dun sa isang sasakyan namin 205/45/16 pa ito 30 psi ang hangin dito. tibay pa 1999 pa ito nakakabit sa sasakyan ng utol ko (almost 5 yrs na pala ito). Pero I would go for Dunlop Formula ganito gamit ko ngayon (195/55/15)
We use LM702s on our rides now since the price is ok... its an everyday tire (not high pef na pang track) but it performs ok in the dry and wet. Our old 701's lasted 5 years and 55,000km on our Sentra.
otep, DUNLOP LE MANS 701 ata un e kc utol ko gumagamit. ang bili namen 2300 each. mga guys tnx s reply nnyo, 25psi lng ung nilalagay kong hangin para hnd matagtag. masama b ito? 195/55/r15 ung size ng tire ko tnx a bunch pasencya n kung madameng tanung... dko pa kasi alm ung mga ito e ty a lot s mga sagot.![]()
25psi won't damage the tire and will give you a better ride, pero your gas consumption will suffer kasi it will increase the rolling resistance and the tire will wear faster than normal.
IMO, 25 is a bit soft and it will affect the tire wear and braking... I'd suggest you try it at 30psi more or less.![]()
