Results 1 to 8 of 8
October 1st, 2007 12:14 PM #1
ESi car. yaw gumana yung door opener sa labas and accidentally na-i-child lock ko. pano ba walkthrough to fix this? kahit man lang ma-open ko sya from the inside. thanks.
October 1st, 2007 01:53 PM #2
October 1st, 2007 02:23 PM #4
Magulo yung tanong mo bro. Pag naka-child lock, it means hindi mo siya mabubuksan sa loob, pero pwede sa labas using the door handle.
Bakit kailangan mo buksan from the inside? Hindi ba gumagana yung power windows?
October 1st, 2007 02:43 PM #5
sir ineedmorehp...nangyari na sa ESI ko yan noong nasira ung door operner ko at nabalian ng small parts sa loob. ito po ung ginawa ng mechanic ko.
1. Inalis po ung door panel from the inside medyo mahirap nga lang.
2. Gumupit cya ng manipis na yero ng korteng pahaba at sinukat nga ung
tapat ng child lock sa kabilang door.
3. Kinapa nya using that tool and luckily natamaan nya at bumukas.
Khit DIY kya mo kci after that sbi ko sa sarili ko madali lang pala. ung door opener 500 lang papalit mo na rin para isang trabaho at bayad.
October 2nd, 2007 10:42 AM #6
^ ah so na sungkit nya yung child lock and was able to use the inside door opener?
October 6th, 2007 06:01 PM #8
high idle RPM at engine start
