Results 1 to 7 of 7
August 2nd, 2005 12:14 PM #1
My car's a '98 corolla xe (163T kms). Paano po ba gawin DIY carb cleaning? Anong brand carb cleaner maganda for my ride? Sabi kasi sa ibang thread, wag basta-basta ipa-overhaul sa kamuning. Ok po ba yung nabibiling carb & fuel injector cleaner that you can just mix with your gas?
- Aug 2003
- 9,720
August 2nd, 2005 12:28 PM #2ang alam ko sa carb cleaner is that it comes in an aerosol spray. tanggal mo lang ung air filter to expose the carburetor, then spray away. maganda kung me kasama ka to rev up the engine; namamatayan kasi pag inispray na naka idle lang.
not sure if you're supposed to rev the engine hard para pumasok talaga ung carb cleaner
August 2nd, 2005 12:49 PM #4
ang alam ko kailangan irev ng mataas ganun kase ang ginawa sa tsikot ko nung pinalinis ko yung carb ko dahil parang namamatay matay siya.
August 2nd, 2005 12:57 PM #5
thanks for the quick replies. i'll just buy the 3M carb cleaner and do it this weekend.
- Aug 2003
- 9,720
August 2nd, 2005 05:51 PM #6i think nakakainterfere sa proper combustion ung pag spray sa carb kaya namamatay...not enough air going into the mix, perhaps?
- Jun 2004
- 1,311
August 23rd, 2005 10:54 PM #7Earlier DIY carburetor cleaning ginawa ko, bumili lang ako nung cleaner sa Ace Hardware, 169 pesos sya. Then I just removed the air filter and sprayed into the carb while revving the engine, nung medyo bumaba yung rev namatay makina, kelangan talaga naka rev yung engine around 4-6,000rpm.
