Results 1 to 7 of 7
    Apr 2005
    My car's a '98 corolla xe (163T kms). Paano po ba gawin DIY carb cleaning? Anong brand carb cleaner maganda for my ride? Sabi kasi sa ibang thread, wag basta-basta ipa-overhaul sa kamuning. Ok po ba yung nabibiling carb & fuel injector cleaner that you can just mix with your gas?
    Aug 2003
    ang alam ko sa carb cleaner is that it comes in an aerosol spray. tanggal mo lang ung air filter to expose the carburetor, then spray away. maganda kung me kasama ka to rev up the engine; namamatayan kasi pag inispray na naka idle lang.
    not sure if you're supposed to rev the engine hard para pumasok talaga ung carb cleaner
    Dec 2003
    ang alam ko kailangan irev ng mataas ganun kase ang ginawa sa tsikot ko nung pinalinis ko yung carb ko dahil parang namamatay matay siya.
    Apr 2005
    thanks for the quick replies. i'll just buy the 3M carb cleaner and do it this weekend.
    i use 3M carb cleaner tuwing tune-up ng tsikot ko.
    Aug 2003
    i think nakakainterfere sa proper combustion ung pag spray sa carb kaya namamatay...not enough air going into the mix, perhaps?
    Jun 2004
    Earlier DIY carburetor cleaning ginawa ko, bumili lang ako nung cleaner sa Ace Hardware, 169 pesos sya. Then I just removed the air filter and sprayed into the carb while revving the engine, nung medyo bumaba yung rev namatay makina, kelangan talaga naka rev yung engine around 4-6,000rpm.
DIY carb cleaner
