Results 11 to 18 of 18
DIY to death!
- Jan 2003
- 451
November 16th, 2007 10:20 AM #12This should be a non-issue since everything would be ultimately getting its current from the battery. As long as your charging system and voltage regulator are working fine, you should be ok.
Again, this would be a non-issue as long as the total current draw of all devices is something that the battery and charging system can handle.
A device will only draw enough current to satisfy its needs. Problems will occur if the power source cannot supply it. If it can, but the wiring has too much resistance (too old, damaged, etc), then the same thing happens. So new wiring is laid out and switched via the old wiring through a relay.
Each relay does consume a small amount of current in order to work the switch, but this is usually negligible. So yes, it does add up, but probably not enough to be concerned about.
HTH.
DIY to death!
- Jan 2003
- 451
November 16th, 2007 10:27 AM #13
November 17th, 2007 11:29 AM #15
i have relays on horn, headlight, foglights. ano bang pinakamatibay na relay sa lahat?
November 17th, 2007 12:22 PM #16
of too many relays means too many devices to be checked during failure/s.
sa kaso ng overrated devices, ang hdlights ang notorious kasi kahit sa stock relays lang eh tlagang super umuinit sya so, lalo na yun kung overrated ang pinalit mong hdlight. so dapat additional relay.
it is ok kung parallel connection ang gawin kasi kahati ng second relay ang current load ng device. malaki ang bawas ng heat dissipation. kaysa series na "a relay to drive a relay to drive a device."
Take note na yung 1st relay(yung original relay) ay galing sa fuse. so ang second relay if connected in parallel ay lagyan mo ng redundant fuse wired directly from the battery, only the coil supply is parallel, being shared by both relays.
November 20th, 2007 04:38 PM #18
Medyo OT: Readily available ba ang mga relay terminals na may lock like those that come with el cheapo relay sockets? Pinalitan ko kasi lahat ng terminals ko dahil gauge 14 ang nakakabit na wire at gusto ko thicker wire ang gamitin. Problem is yung mga terminals na nabili ko walang locks so friction lang ang humahawak sa kanila. Scary I know. Had to drive from Makati to San Juan on foglights dahil natanggal yung power ng low beam relay
Xiaomi E-Car
