Results 1 to 10 of 17
Threaded View
- Sep 2019
- 23
October 12th, 2019 01:56 PM #1Good day mga sirs, maginquire lang po ako. just bought a 2009 Honda City AT. So far no problem naman sa takbo. I'm starting to do maintenance na din as per the service manual.
ask ko lang kasi dalawang tao na po nagsabi sakin na need ko din palitan differential fluid oil nito, pero base sa service manual, wala naman po specs or scheduled maintenance sa differential.
also, i'm planning to diy atf change, ask ko lang if CVT na po ba ang transmission assy ng model na to? as per manual, atf z1 ang recommended and base sa nababasa ko dito, z1 was already replaced by dw-1 fluid. ok lang ba gamitin to?
btw so far smooth shifting pa yung gears as of the moment, gusto ko lang manigurado na tamang fluid and mailalagay
At the expense of rear cargo space. The floor is raised around 8inches for the batteries.
2021 Toyota Land Cruiser LC300
