Results 1 to 10 of 17
- Sep 2019
- 23
October 12th, 2019 01:56 PM #1Good day mga sirs, maginquire lang po ako. just bought a 2009 Honda City AT. So far no problem naman sa takbo. I'm starting to do maintenance na din as per the service manual.
ask ko lang kasi dalawang tao na po nagsabi sakin na need ko din palitan differential fluid oil nito, pero base sa service manual, wala naman po specs or scheduled maintenance sa differential.
also, i'm planning to diy atf change, ask ko lang if CVT na po ba ang transmission assy ng model na to? as per manual, atf z1 ang recommended and base sa nababasa ko dito, z1 was already replaced by dw-1 fluid. ok lang ba gamitin to?
btw so far smooth shifting pa yung gears as of the moment, gusto ko lang manigurado na tamang fluid and mailalagay
October 12th, 2019 02:42 PM #2
The 2009-2013 City/Jazz has the traditional torque converter 5-speed AT tranny. You have to use the Honda ATF DW1 fluid and change it every 40k km. You will need around 4L for the usual drip and refill method. Since FWD yung kotse, wala sya differential only the transaxle but this is part of the tranny assembly.
Sent from my iPhone using TapatalkLast edited by Egan101; October 12th, 2019 at 02:46 PM.
- Sep 2019
- 23
- Aug 2017
- 319
- Jul 2009
- 2,618
October 13th, 2019 11:08 AM #5
October 13th, 2019 11:37 AM #6
- Jul 2009
- 2,618
- May 2017
- 2,099
October 13th, 2019 07:16 PM #8Hi, we also have a Honda City CVT 2016, when it comes to the change oil and change filter part, yun bang ordinary change oil nito pwede ba ang Top1 Motor Oil for the Honda City engine?
October 13th, 2019 07:23 PM #9
- Jul 2013
- 2,450
October 14th, 2019 09:51 AM #10
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
