Results 1 to 4 of 4
- Jul 2012
- 113
November 28th, 2016 04:22 PM #1Hi mga Guru's,
Ask lang po ako advised, yung kotse nang kapatid ko nasagi then na defused ang airbag then may warning na sa dashboard yung airbag.
Ask lang how much po abotin pagawa ng airbag and all?
Thanks
- Jun 2005
- 3,774
November 28th, 2016 04:52 PM #3
What do you mean by defused? It got disabled or did it deploy?
Either way, ask your dealer. Anything to do with passenger restraints (seat belt pre-tensioners) and SRS (airbags), the only qualified entity that can restore them safely and reliably is your casa.
If it's the other driver's fault, his insurance should cover it. Otherwise, if your have a comprehensive insurance, check if there's an airbag clause. If so, you can try claiming it as part of the accident. Anyway, the restoration must be performed by a qualified techie, most likely, the car dealer of your brand.
- Feb 2017
- 8
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
