Results 1 to 10 of 13
July 19th, 2007 04:40 PM #1
mga sir, yung left cv joint ko went loose last week nun nakapark ako (good thing)..naubos un power steering fluid (nabuhos sa ilalim nun car)...then i had to buy a replacement for the loosed cv joint....naikabit na cya ng mekaniko kahapon. Ngaun naman maingay ung right side na cv joint (especially paglumiliko pakaliwa)...ano po kaya problem?...nde kaya kulang lang ung power steering fluid na inilagay? ala po kc ako nun kinabit un left cv joint, so nde ko nakita kung nag-bleed ng power steering. posible po kya na cra din un right cv joint or any parts pa po dun ang posibleng may cra?...'93 bluebird altima po ride ko.
July 19th, 2007 05:31 PM #2
Kwik,
Some questions lang.
Are you sure Constant Velocity Joint ang nag loose?
How is the steering fluid involved with problem?
July 19th, 2007 05:39 PM #3
sabi po kc nun mekaniko cv joint daw un....nagpabili lang ako nun sa kanya sa banawe.cya na din nagkabit....ang nkita ko lang po ung "boot" na bago na ikinabit nya...mali po ba? (senxa na po, taga-gamit lang at taga-cra ng oto )
July 19th, 2007 05:45 PM #4
sir, naubos un power steering fluid nun natanggal un bakal na un eh (sabi daw cv joint nun mekaniko)....mali po ba?pero sa may boot po cya malapit.senxa na po ha, newbie lang d2 tsikot.
July 19th, 2007 05:49 PM #5
AFAIK, walang connection ang PS fluid sa CV joint. Get a second opinion nalang. Baka malapit na dim bumigay ang right cv joint mo. Mabuti at hindi ka inabutan at high speeds. Next time have regular check-ups para iwas accidente.
HTH.
July 19th, 2007 05:58 PM #6
i'll have it check sa servitek na lang dis wikend para walang kaba...nde ko na nga ginamit un oto baka kumalas na lahat sa kalsada....TIA
DIY to death!
- Jan 2003
- 451
July 19th, 2007 06:11 PM #7When you said it "went loose", what exactly was the effect? You couldn't steer anymore or the car doesn't move?
July 19th, 2007 06:23 PM #8
i could still feel the right wheel moving while inside the car, pero nun kinabig ko na pakaliwa, nde na sumusunod un gulong....paglabas ko ng oto, the left wheel was in an "inward position" facing the car (parang "piki" na cya). The car doesn't move and wala ng control un manibela sa left wheel....pagtingin ko sa ilalim ng oto, kumalat na un power steering fluid.
DIY to death!
- Jan 2003
- 451
July 19th, 2007 06:37 PM #9Mukha ngang hindi CV joint yan, baka yung steering linkage ng left wheel. The car doesn't move kasi nga na-piki na.
July 19th, 2007 06:42 PM #10
di bale,sir...kausapin ko mekaniko when i get home...ipa-chek ko n lng sa mas cgurado...ipost ko po tomorrow kung anong part un natangal...thank you po mga sir...
Xiaomi E-Car
