Results 1 to 13 of 13
    mga sir, yung left cv joint ko went loose last week nun nakapark ako (good thing)..naubos un power steering fluid (nabuhos sa ilalim nun car)...then i had to buy a replacement for the loosed cv joint....naikabit na cya ng mekaniko kahapon. Ngaun naman maingay ung right side na cv joint (especially paglumiliko pakaliwa)...ano po kaya problem?...nde kaya kulang lang ung power steering fluid na inilagay? ala po kc ako nun kinabit un left cv joint, so nde ko nakita kung nag-bleed ng power steering. posible po kya na cra din un right cv joint or any parts pa po dun ang posibleng may cra?...'93 bluebird altima po ride ko.
    Kwik,
    Some questions lang.
    Are you sure Constant Velocity Joint ang nag loose?
    How is the steering fluid involved with problem?
    sabi po kc nun mekaniko cv joint daw un....nagpabili lang ako nun sa kanya sa banawe.cya na din nagkabit....ang nkita ko lang po ung "boot" na bago na ikinabit nya...mali po ba? (senxa na po, taga-gamit lang at taga-cra ng oto )
    sir, naubos un power steering fluid nun natanggal un bakal na un eh (sabi daw cv joint nun mekaniko)....mali po ba?pero sa may boot po cya malapit.senxa na po ha, newbie lang d2 tsikot.
    AFAIK, walang connection ang PS fluid sa CV joint. Get a second opinion nalang. Baka malapit na dim bumigay ang right cv joint mo. Mabuti at hindi ka inabutan at high speeds. Next time have regular check-ups para iwas accidente.
    HTH.
    i'll have it check sa servitek na lang dis wikend para walang kaba...nde ko na nga ginamit un oto baka kumalas na lahat sa kalsada....TIA
    Jan 2003
    When you said it "went loose", what exactly was the effect? You couldn't steer anymore or the car doesn't move?
    Quote Originally Posted by Yoda View Post
    i could still feel the right wheel moving while inside the car, pero nun kinabig ko na pakaliwa, nde na sumusunod un gulong....paglabas ko ng oto, the left wheel was in an "inward position" facing the car (parang "piki" na cya). The car doesn't move and wala ng control un manibela sa left wheel....pagtingin ko sa ilalim ng oto, kumalat na un power steering fluid.
    Jan 2003
    Mukha ngang hindi CV joint yan, baka yung steering linkage ng left wheel. The car doesn't move kasi nga na-piki na.
    di bale,sir...kausapin ko mekaniko when i get home...ipa-chek ko n lng sa mas cgurado...ipost ko po tomorrow kung anong part un natangal...thank you po mga sir...
    Most probably he was refering to the draglink or rackend. May rubber boot din yunand will empty your PS fluid when it gets loose or is remove from its mount. You should have seen it coming by way of knocking noise over potholes especially bumps during turns. Good thing you didn't hit a pothole doing soemthing over 20kph.
    mga sir, i just came from servitek malapit sa'amin...rack end daw po un ntangal sa left...nun tinawagan ko un mekaniko nmin, ibang sasakyan pala un cnabi nya na cv joint un cra (un sa van pla ni erpats )....sabog kausap eh..anyways, i had it fixed na....tapos un right rack end, dapat daw palitan na din kc baka masira na kaya tumutunog na din...pasenxa na po mga sir, nde ko lam mga parts ng oto e. lesson learned: maintenance check-up po para iwas disgrasya. swerte pa rin, the left rack end went off while i was parked outside the house (masamang damo, matagal machugi ).Thank you, mga sirs.
    Ayos good to go na ulit tsikot mo! Kakapaayos mo ng sasakyan you'll get familiar with these parts. Drive safe.
CV joint problem
