Results 1 to 18 of 18
    hey guys... my dad's CRV year model 2000 is nearing 40,000km already.
    besides change oil, oil filter, transmision oil.... is there any other things i should do?
    should i replace spark plugs already? (never been replaced)what else?
    what other fluids should i replace?
    what should i lubricate?
    whaaat? spark plugs never been replaced at 40,000 kms? imho, diba dapat every 10k ang palit ng plugs?
    other things you might check:
    a) radiator flush
    b) brake fluid replacement
    c) power steering fluid replacement
    d) tire rotation/balancing/camber check
    e) aircon cleaning/check
    f) air filter replacement/check/cleaning
    dami pa....
    tenks happy gilmore! better get my pen n paper!
    ano pa?
    pansin ko kasi loss of power na eh. parang humina na ang pulling power nya.
    check your manual
    kasi sa manual its the usual. change this change that?
    how about lubircating? of course mdyo naluluma na tsikot kelangan grasahan ulet kung ano man dapat grasahan.
    erap, suggestion lang...
    why not bring it to honda mismo for a heavy PMS? i know it can be expensive, but it is worth it...
    madugo kasi eh. okay sana kung makakatipid ako kahit konte.
    IMHO,
    to have your car properly maintained, bring it to the casa every 10K. then you can DIY the maintenance in between.
    also, check your manual. usually at 40K there is not much to do other than the normal PMS routine. oil, oil filter, air filter, coolant, battery water, brake fluid, alignment, fuel filter, spark plugs, etc
    for the spark plugs, have it checked if the CR-V is already using the denso iridium plugs. AFAIK, the Cefiro and Rav4 is already using those and needs replacement only every 100K.
    Kung gusto mo makatipid, follow the procedures in your manual pero sa talyer or gas station mo dalhin.
    jan na nakaka miss si MARC gas station!!! pero yung mga caltex express lube ok naman ang service...
    san ko makikita caltex xpress lube?
    dieselNubi,
    check this out:
    http://www.hondashaw.com.ph/PreventiveMaintenance1.htm
    40,000 km., 120,000 km., 200,000 km. Preventive Maintenance Check
    Change Engine Oil and Filter
    Replace Transmission Oil
    Replace Engine Coolant
    Replace Fuel Filter (Carburator and PGM-FI)
    Inspect Tie Rod Ends, Steering Gearbox and Boots
    Inspect Suspension Mounting Bolts
    Inspect Exhaust System
    Inspect Brake Lines and Connections
    Inspect Front and Rear Brakes
    Inspect Driveshaft Boots
    Inspect Fuel Tank, Fuel Lines and Connections
    Inspect Belt Tension and Conditions
    Inspect Distributor Cap and Rotor
    Inspect Valve Clearance
    Replace Air Cleaner Element
    Replace Spark Plugs
    Inspect Ignition Timing and Idle Speed
    Inspect Positive Crankcase Ventilation Valve
    Replace Brake Fluid
    Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer)
    Inspect Battery Electrolyte Level
    Inspect Compressor Clutch and Joints
    Inspect Condenser Of Dirts and Insects
    Inspect Freon Gas Level (Check Sightglass For Bubbles)
    Inspect Engine Cooling Lines and Connections
    Inspect Steering Pump, Lines and Connections
    Inspect Parking Brake Adjustment
    Inspect Clutch Free Play
    Rotate Tires (Check Conditions, Wear And Pressure)
    40t km is a major service interval. Palit lahat ng fluids. pag plano po pagawa sa labas use other brands ng coolant. Mahal kase yung Honda Green Fluid at Php700 a bottle.
    Manual Tranny ba yan?: pag M/T use motor oil na 10w-40 or 20w-50. Don't use gear oil for Hondas.
    Pag A/T naman use Honda ATF. As for the RTAWD differential ATF din gamit dun. Brake fluid naman is DOT4
    HTH
    AT po sya.
    actually baka next month ko pa ito i papa PMS. im just making a check list of what should i do.
    yes 40,000 km PMS is a heavy PMS!
    Nov 2003
    pass by the shop if you like we can do all the required pms for you
    re: the loss of pulling power, that's probably the sparkplugs/air filter due for a change.
    Dec 2002
    The throttle body opening should be cleaned too by spraying it with a carb cleaner, will help smoothen out the idling.
    I'd check all 4 shocks by actually pulling them out- "showa" shocks don't last that long.
    Crv bushings are weak: replace trailing arm, strut bar bushings.
    Use Honda PSF only for power steering.
    A good Dex 3 ATF should do for transmission and rear diff.
    If repairs are never ending- sell the car!
    speedyfix, san po shop nyo?
    jackaroo, magkano aabutin yan sinasabi mo? tancha lang.
    Dec 2002
    dieselnubi,
    estimates only:
    Shocks- P5k
    bushings- P3k
    Honda PSF- P280/L
    Dex3 atf- P130/L
    Nov 2003
    we're located along shaw boulevard right beside toyotaÜ
CRV nearing 40,000 km ... what to do?
