Results 11 to 18 of 18
March 3rd, 2004 09:56 PM #12
dieselNubi,
check this out:
http://www.hondashaw.com.ph/PreventiveMaintenance1.htm
40,000 km., 120,000 km., 200,000 km. Preventive Maintenance Check
Change Engine Oil and Filter
Replace Transmission Oil
Replace Engine Coolant
Replace Fuel Filter (Carburator and PGM-FI)
Inspect Tie Rod Ends, Steering Gearbox and Boots
Inspect Suspension Mounting Bolts
Inspect Exhaust System
Inspect Brake Lines and Connections
Inspect Front and Rear Brakes
Inspect Driveshaft Boots
Inspect Fuel Tank, Fuel Lines and Connections
Inspect Belt Tension and Conditions
Inspect Distributor Cap and Rotor
Inspect Valve Clearance
Replace Air Cleaner Element
Replace Spark Plugs
Inspect Ignition Timing and Idle Speed
Inspect Positive Crankcase Ventilation Valve
Replace Brake Fluid
Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer)
Inspect Battery Electrolyte Level
Inspect Compressor Clutch and Joints
Inspect Condenser Of Dirts and Insects
Inspect Freon Gas Level (Check Sightglass For Bubbles)
Inspect Engine Cooling Lines and Connections
Inspect Steering Pump, Lines and Connections
Inspect Parking Brake Adjustment
Inspect Clutch Free Play
Rotate Tires (Check Conditions, Wear And Pressure)
40t km is a major service interval. Palit lahat ng fluids. pag plano po pagawa sa labas use other brands ng coolant. Mahal kase yung Honda Green Fluid at Php700 a bottle.
Manual Tranny ba yan?: pag M/T use motor oil na 10w-40 or 20w-50. Don't use gear oil for Hondas.
Pag A/T naman use Honda ATF. As for the RTAWD differential ATF din gamit dun. Brake fluid naman is DOT4
HTHLast edited by Supierreman; March 3rd, 2004 at 10:04 PM.
March 4th, 2004 02:23 AM #13
AT po sya.
actually baka next month ko pa ito i papa PMS. im just making a check list of what should i do.
yes 40,000 km PMS is a heavy PMS!
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 4th, 2004 08:37 AM #14pass by the shop if you like we can do all the required pms for you
re: the loss of pulling power, that's probably the sparkplugs/air filter due for a change.
Tsikot Member Rank 3
- Dec 2002
- 636
March 10th, 2004 07:48 PM #15The throttle body opening should be cleaned too by spraying it with a carb cleaner, will help smoothen out the idling.
I'd check all 4 shocks by actually pulling them out- "showa" shocks don't last that long.
Crv bushings are weak: replace trailing arm, strut bar bushings.
Use Honda PSF only for power steering.
A good Dex 3 ATF should do for transmission and rear diff.
If repairs are never ending- sell the car!
March 10th, 2004 08:06 PM #16
speedyfix, san po shop nyo?
jackaroo, magkano aabutin yan sinasabi mo? tancha lang.
- Dec 2002
- 636
March 11th, 2004 09:54 PM #17dieselnubi,
estimates only:
Shocks- P5k
bushings- P3k
Honda PSF- P280/L
Dex3 atf- P130/L
- Nov 2003
- 3,849
Daming issue ng SU7:grin:
Xiaomi E-Car
