Results 1 to 10 of 13
- Jan 2004
- 40
February 25th, 2004 06:35 PM #1Guys, paano ba nililinis yung throttle body ng EFI (yung sa may MAP sensor) , yung kung saan nakatatak yung EFI sa Honda ESI 94. Binuksan ko kasi yung sa akin nasalat ko sa ilalim ng butterfly medjo me build up ng langis. normal ba to ? accumulated through the years kaya ? pede kaya i DIY.
salamat mga tsikot-peeps.
February 27th, 2004 08:03 PM #2
di ko kasi kabisado pre.........
pero ang gawin mo pagawa mo muna sa mekaniko. tapos panoorin mo. para nextime ikaw na lang gagawa
- Feb 2004
- 24
February 28th, 2004 03:49 PM #3make sure pag nilinis mo yan spray mo yong cleaner o chemical sa basahan kung hindi taas baba ang idle mo kasi kong may natira na sludge sa mga butas ma iistock doon.
- Dec 2002
- 19
February 29th, 2004 08:38 AM #4I bought a Whiz Carb Cleaner sa Ace Hardware. I remove the plastic tube that connects the throttle body to the air filter. And with the engine running, I sprayed the cleaner inside the throttle body. You have to push the plates inside the throttle body in order to clean the inside. You can do this for several minutes until wala ka nang makita na deposits sa loob ng throttle body.
Hope this helps.
Tsikot Member Rank 5
- Nov 2003
- 3,848
March 1st, 2004 10:14 AM #5spraying degreaser on the outside simply [ushes the dirt further inside which may clog the engine. best solution is to take out the whole intake manifold and have it cleaned nalang while out of the car.
- Jan 2004
- 40
March 1st, 2004 01:30 PM #6Guys, could this be the problem why my idle is not adjusting right, pag tumakbo yung aircon at rad fan ko ?
Pansin ko kasi, bumababa idle ko pag nag on ang aircon compressor ko, tapos bumabalik sa dati pag nag off, diba dapat self adjust sya ? anong sensor ba involve para makabawi yung idle ko pag nag on ang aircon ?
thnaks ulit
- Feb 2004
- 24
March 1st, 2004 03:01 PM #7kung bumababa ang idle mo +- 100 rpm at hindi naman eratic gaano it should be alright normal na mag move ang idle mo a little bit kasi may load siya kagaya ng pag on ang AC mo i cocompensate siya ng tinatawag na Idlel Control Valve.kaya pag namatay yong fan mo bumabalik sa tamang idle which is normaly 700,750 both+-.
March 1st, 2004 05:09 PM #8Originally posted by mister_big_bird
thnaks ulit
I don't know what's the equivalent of the servo for honda engines, it could be the Idle Control Valve or Idle Switch Control Valve. So probably if you have your TB cleaned and also your idle switch whatchamacallit, hopefully it will solve your problem too.
- Jan 2004
- 40
agree. ilang beses ko din pinlitmag-motor daughter ko. kaso ayaw talaga.
Recommended Parking Near De La Salle (Taft)
