ok kung sa oil pan gasket... better check what kind of gasket are u gonna use if its cork or not.
if cork madali kasi madurog if u over torque it. so the simplest solution if ur using cork is basain mo muna then let it dry under d sun. when its dry na matigas na yan. then install it na.
