Results 1 to 10 of 10
    Oct 2003
    my car is an '06 honda city cvt. minsan kasi ayaw magstart yung car ko eh. i dont know if my alarm (autopage) is causing my problem. the autopage kasi may starter cut-off eh. initially i was wondering kung dat was the problem baka kasi nagloloko pero i had the starter cut-off relay checked sa blue lazer (distributor ng autopage) ok naman daw.
    no click whatsoever pero ok naman yung battery (i just change this like 3 months ago)
    i also had honda q ave check my electrical system. ok naman daw lahat.
    pag ayaw magstart normally, i do the shift lock maneuver just to start the car, but sometimes that doesn't even work. pero after a while magstart na ulit siya. minsan naman i just turn the key and mmya bigla na lang siya magstastart after a long delay.
    could it be my starter?
    i'm running out of ideas na kung ano yung problema.
    help please?
    Pa check mo sa ibang casa bro. malamang starter nga . .
    Nov 2007
    starter nga cguro baka naninikit???
    bago pa yan honda mo ah?
    tama si bro mazinger z, try to get a 2nd opinion in another casa. baka matumbok din ang problema niyan
    Sep 2004
    Pwede rin yung starter solenoid. Pero bago pa kasi car mo eh...hmmm...
    Dun sa Accord ko kasi, akala ko rin yung starter kill ng Clifford alarm ko, kasi ni click wala. Nakalagay naman sa P or N yung selector ng tranny. Nung binaba yung starter, akala ko brush pero starter solenoid lang pala.
    Nov 2003
    if it's an 06 model then you're under warranty pa. bring it to your dealer.
    Quote Originally Posted by zechs View Post
    help please?
    I think I used to have that problem kapag turn ng key walang redondo, pero okay naman charging system, battery and starter.
    I remember my mechanic friend put a relay between the battery and an electric wire leading to the engine (can't remember exactly where it leads to) after that okay na.
    HTH
    nangyari na din sakin yung ganyan. tiningnan kong lahat ng electrical pati alarm. Ang culprit pala ay lumuwag yung turnilyo ng body ground ko.
having problems with my honda city cvt
