Results 1 to 8 of 8
November 15th, 2005 10:40 AM #3
maitim at may parang red kul*ngot ang loob ng carb kapag tinignan mo ito.
at parang kinakapos sa gasolina at hangin ang engine mo.
November 15th, 2005 11:09 AM #4
If your car:
1) starts reluctantly
2) Backfires
3) Stalls
4) Lose power at high or low rpm,
Then that's the time your carb requires cleaning/overhaul.
Toyota is my choice
- Aug 2005
- 2,063
November 16th, 2005 07:57 AM #5and 1 more kpag may hissing sound like air going out from the carb..
November 16th, 2005 03:20 PM #6
Originally Posted by finchy18
Toyota is my choice
- Aug 2005
- 2,063
November 16th, 2005 04:15 PM #7cause maybe barado na at kupal na ang dumi and pa change na ibang parts sa loob.. mahina lng ba ang singaw galing sa carb mo? pwde mo rin yan pa check sa magaling na mechanic anywaz free nman check up.. sakin kasi yun pina overhaul na talaga malakas ang singaw at naririnig ito kahit nasa loob ka ng car with stereo off (ma ingay talaga) at pagkatapos nun pina overhaul kuna kasi loose of compression na din or power..
last pala yong need na talaga pa overhaul sya kasi kpag 60-80kph na takbo mo pag shift mo ng neutral bigla lang mamatay engine mo tapos mag run na uli.. be carefull sa dyan bro.. hope u can get fix that asap.. gud luck!Last edited by finchy18; November 16th, 2005 at 04:19 PM.
Ford kasi... it needs a lot of TLC. ;) Kidding aside, I don't know if other turbo vehicles have...
0dometer problem
