Results 11 to 17 of 17
November 2nd, 2007 11:33 PM #11
ganito kasi yun po, pag start ko, 1 click lang..then shempre pag start ng engine medyo nakatapag ako sa gas pedal, pero pag binitawan kona, parang hirap yung engine at mamamatay siya..
pag rev naman ako ng rev, panget yung tunog niya...parang bumubula yung muffler niya...pero pag nag idle na siya..ok na lahat..
Thanks,
BANNED BANNED BANNED
- Jul 2003
- 2,267
November 2nd, 2007 11:40 PM #12afaik, this is not necessarily true. carbureted engines have fast idle during cold starts. like in 4AF engines, fast idle should be like 3000rpm. then after a while, the rpm returns to normal.
check mo yung choke before a cold start. dapat closed siya para rich yung fuel mixture. mag open din siya after mo ma start yung engine.
November 2nd, 2007 11:42 PM #13
- 3,790
November 3rd, 2007 03:15 PM #14open the filter housing/cover... close yun pag sarado ang throttle with the "butterflies".
Choking means no air (or limited air) so pagsinara mo ang butterflies machochoke un.
November 4th, 2007 06:24 PM #15
ganyan din prob ko sa oto ko, pag cold start sobra baba rpm tapos parang mamamatay pero pag nagtagal naman o naginit na makina o kaya tumakbo na ok na ung rpm nya, last week lng ko nagpatune-up, nakita prob ng mekaniko pag on ko ng aircon sobra bumaba rpm un pla di gumagana ung actuator valve switch kaya pinalitan nya ok na naman kaso ang problema ko ngyn e pag coldstart klangan mo pa antay ilang minuto o kaya itakbo na bago magstable rpm/idle nya..
November 4th, 2007 08:31 PM #16
try mo pre i adjust yung turnilio sa baba ng carb mo kung meron yan,bali malapit sya sa hose ng tubig galing ng water pump,pa clock wise ang ikot
November 7th, 2007 11:50 AM #17
ok na otobot ko sa wakas...
the problem was the automatic choke..may konting kalawang sa loob niya...kinalkal kolang at spray ng WD40 then brush with toothbrush tapos kinabit ko..ayun..swabeng swabe na siya..
Salamat mga repapips...
God bless this forum...
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
