Results 1 to 10 of 15
- May 2006
- 3
September 20th, 2006 02:40 PM #1Hello everyone,
Hingi lang po ako advice. My car is kia pride cd5 91. Ang problema sobra takaw nya sa gas. I think 5km/l lang sya or less. This is anomalous kasi ang alam ko ang kia ay matipid sa gas dahil 1.3 sya at magaan.
At saka kelangan pa sya i rev ng couple of minutes on first start (painitin) para maging stable ang rpm.
Another thing nagcchoke sya kapag binabaan ang idle rpm. Ngayon nsa 1000 ang idle rpm ko.
Di nmn po sya palyado, and la problem ang battery ko. Me tama po ung float ng carb ko, naputol, so dinikit n lang ng mighty bond ng mechanic ko..
Help nmn mga tol, kasi angmahal ng fuel consumption ng ride ko.
Thanks,
September 20th, 2006 03:12 PM #2
Napa-tune up mo na ba? Try replacing all filters (oil, fuel, air) into fresh ones (kahit replacement). Yung fluids nagpalit ka na recently?
Baka din wala sa tono ang carb mo, masyadong maraming fuel na dinedeliver (rich).
September 20th, 2006 03:56 PM #3
in addition to the above post, try cleaning the ICV and the TB as well...
IMHO you're running rich...
- Sep 2006
- 46
September 20th, 2006 05:14 PM #5try mo pa tune so magaling na mechanic, wag sa baka sakali na mekaniko.. and palitan mo fuel filter, carb repair kit, spark plugs.. pa compression test mo na rin..
- 10,620
September 20th, 2006 11:59 PM #7
- Aug 2006
- 337
- May 2006
- 3
September 21st, 2006 10:00 AM #9Thanks sa lahat ng reply nyo..
Actually katutune-up nya lang, i guess 1 month ago. pnalitan ang sparkplug, changed oil, change to NGK spark plug, me konting kinalikot sa carburetor. Tinry ng mechanic na timplahin ang rpm, bumibilis bumabagal kasi ang rpm ko. Wala din nagawa, kaya tinaasan na lang ang rpm.
Questions:
1. Ano po ba ang normal na rpm ng kotse?
2. Di kaya me kelangan lang iadjust sa carburetor ko para tumipid?
3. Magkano po ba magpalit ng brand new n carburetor. Kasi sira n ang float nuon eh, la na yata nabibiling ganung piyesa..
4. Ano po kaya kelangan kong gawin para di ko na kelangan painitin ang makina ko para maging normal ang rpm?
September 21st, 2006 10:03 AM #10
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
