Results 21 to 30 of 33
- Aug 2007
- 19
September 20th, 2007 04:20 PM #21tama ka jan bro, galing talaga ng tsikot, newbie din ako walang alam sa kotse but I make it a point to read tsikot thread everyday, kaya medyo may alam na din. when i want to know something about cars, open ko lang tsikot. Big help yung mga gurus dito sa tsikot esp " theveed ". mine is lumang lancer glxi 1996 a/t wala pa namang problema, but i'm reading as much as i can dito sa tsikot para ready na ako kung may kailangan i-pagawa. goodluck mga bro.
September 20th, 2007 09:22 PM #22
yup, ako din thankful kasi nalaman ko itong tsikot. dami ko talaga natutuhan. saka malaking tulong sya lalo na sa case ko.
September 21st, 2007 01:02 AM #23
- Sep 2007
- 16
September 24th, 2007 05:50 PM #24Ask ko lang mga sir, san po ba ung speedyfix? kaya po ba nila ang overheat? Kasi po ung car ko po nag-overheat sya kapag traffic at nakaon ang aircon pero habang tumatakbo at naka-on ang aircon ok naman po sya. Ano po kaya problem nun...sensya na po a...ilang beses na rin ako naloko sa banawe...purkit girl ako inaabuso ako...hehehehe...nissan 1995 po ung car ko...tnx!
September 24th, 2007 05:55 PM #25
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 24th, 2007 06:19 PM #26Speedyfix is in Shaw Blvd. Across Red Ribbon and almost beside Pure Gold. They have a big signage. Tel no 717-4202 look for Migs.
Kung di ka nagoverheat pagoff ang aircon, most likely aircon fan ang prob.
The reason it heats up during traffic is the AC fan can not push enough air to cool your engine. When running, you have enough airflow to keep your car cool.
Simple test you can so is open the hood. Start the car and let it idle till it reaches normal operating temp. 1 fan should start up. Turn on AC, the other fan should also run. That, 2nd fan is your AC fan. If it does not run or is slower than your other fan, you found the culprit.
September 24th, 2007 09:03 PM #27
meron po ba ditong taga bulacan o merong may alam na shop sa bulacan na magaling mag overhaul ng civic engine?
Salamat...
September 25th, 2007 05:29 AM #29
- Jul 2007
- 46
February 27th, 2008 12:19 AM #30bro, wag kang magpa repair kung kahit saan saan, pa repair ka dun sa medyo kilalang mga shops, wag din dyan sa rapide, dami ko ng narinig na negative feedback tungkol dyan and na witness ko mismo yung inconsistency nila sa pag gagawa ng service. basta as long as mapagkatiwalaan yung shop. recommended sa CASA tlaga which i usually have my car fixed since they really know what they are doing.
high idle RPM at engine start
