Results 11 to 20 of 32
June 4th, 2005 08:31 PM #11
Zee Carplus is confident that they can correct the 'camber.' Haven't tried though.
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 5th, 2005 12:33 PM #12whoever says it can be cambered without a camber kit or without cutting up, heating or modifying your suspension in one way or another is yanking your chain.
June 6th, 2005 12:15 PM #13
for the front, you need aftermarket camber kits, for the rear it can be corrected using camber shims.
never go for the heating and other methods that would compromise the integrity of your suspension parts.
June 6th, 2005 07:49 PM #14Originally Posted by bigfeather8888
it can be pala by heating, kaya lang me consequence.nasa me ari nayan kung gusto niya o hindi
August 23rd, 2005 03:55 PM #15
my EK needs a camber na rin. anybody know where i can buy those aftermarket camber kits and how much they cost?
August 24th, 2005 03:19 AM #16
Eibachs are sold at around 10K a pair in tirerack.com. I'm not sure if other brands are available.
It's too bad the EK's front camber is fixed to a negative alignment. It's an economy car and most owners of which want equal tire wear. I myself wouldn't have a problem were it fixed to zero.
- Nov 2003
- 3,849
- Oct 2003
- 2
August 25th, 2005 11:15 AM #18i have a problem with my rear..negative yung tires..what do i need to do? im using neuspeed 2inich drop and stock shocks..my ride is civic lxi
- Mar 2005
- 354
August 25th, 2005 02:07 PM #19ako din problem front tires ng sentra ko. naging sakang nung nagpaayos ako ng shocks sa zee. fixed din front camber ng sentra. san po banda maganda magpa camber?
Thanks
August 25th, 2005 03:07 PM #20
I know Minerva can do it, I've had my Sentra's camber fixed there before... but since this involves drilling out and adjusting the holes where the strut tower meets the wheel hub, it needs to be adjusted again and again afterwards, every five to ten thousand km or so, as the bolts still slip sideways within the holes after long use.
The back can't be cambered at all... not unless you're willing to have the beam bent... but there aren't any local shops that can do this reliably.
Traffic!
