Results 1 to 10 of 10
    May 2013
    Guys san kaya nakakabili ng battery tie down? napansin ko kasi wala akong battery tie down nung nabili ko yung 2nd hand na vios ko.
    Quote Originally Posted by wulberin View Post
    eto ba yung pang series ng kotse at pagparallel ng battery?
    if yes, sa ace hardware madami niyan price range from 450 to few buck above 1000.
    Oct 2011
    jumper cable tawag namin dyan. battery tie down pala other term.
    Feb 2009
    if you are talking about battery hold down, you are better off using a used or surplus one. the fit is important since the gap between the hood or bonnet and the battery hold down is close and it should restrain the battery from jumping up and down when you hit bumps on the road. your corolla has top post or terminal battery that risk the hood bridging the terminals when it makes contact
    nakita ko sa sulit
    battery tie down
    madali lang magpagawa sa machine shop
    battery clamp or battery tie down clamp or battery hold-down clamp. plastic or metal.
    isama mo na rin ang isang pares ng metal L-end bars with screws. ito yung mag-kokonekta ng clamp sa ilalim ng battery stage.
    marami niyan sa auto parts stores or battery stores. dalhin mo ang kotse at may sukat ang mga iyan.
    mura lang. mahal na ang 150 kesos lahat-lahat..
    May 2013
    sir sa mga motolite branches kaya meron sila?
    dun sa motolite suki ko, 'di kapani-paniwala nguni at wala! buti na lang, meron sa katabing auto supply. pedro gil... malapit sa paco market.
    in front of BPI, corner singalong street, beside Lawton Auto Supply.
    hehehe di obvious na taga dyan ako.
    250 petot ata bili ko sa banawe last time. Corolla at Adventure ng tropa parehong nawala ang tie downs from previous owners.
Battery Tie Down
