Results 1 to 10 of 10
July 12th, 2004 05:00 PM #1
Ang intercooler fan ba ng paj e ngtuturn-on pg ignition mo? Yung sa akin kasi kahit umaandar na engine naka off pa rin yung fan.
July 12th, 2004 07:32 PM #2
The Intercooler fan is turned on by a thermal switch. So, if its hot outside, even if you put the key in the on position, it will still work. but notice sa umaga, before you start, it doesnt do that.
July 14th, 2004 10:36 AM #3
Thanx for the reply. Ang problema nga lang kasi khit na tumakbo na ako for about 70 kms and its really hot outside, when you look inside the hood with the engine still running, the fan still isn't turning.
July 14th, 2004 11:14 AM #4
Its either the fan or the fuse is busted. what i did before was override the thermal switch by shorting the wires. what happened was that my fan was always on.
July 14th, 2004 11:34 AM #5
Thanks. BTW is there a noticeable difference in performance if the fan is turning or not? Just curious...
July 14th, 2004 11:36 AM #6
Thanks. BTW is there a noticeable difference in performance if the fan is turning or not? Just curious coz for as long as I can remember di na talaga umaandar yung fan pgkabili ko ng ride.
July 14th, 2004 01:10 PM #7
you wont notice it. Although it does feel better psychologically if you know that it's there
July 19th, 2004 12:27 PM #8
just checked my fan. the damn thing is busted. :arghhh: anybody got an idea how much it costs? thanx
July 19th, 2004 02:55 PM #9
Pa check mo sa Rey's electrical or any other competent auto electrical shop. Madalas, upod lang yung carbon contacts nito. Usually nasa P150 lang ang labor. Yung carbon mura din lang. Hindi dapat lalampas sa P500 all in all.
high idle RPM at engine start
