Contaminants can get in between the clutch disc and flywheel. That's why you should only ford when the coast (pardon the pun) is clear so you don't have to step on the clutch mid-stream.
The engine makes sufficient pressure to clear the exhaust by itself. We are not under 100m of water or anything.
The habit is hard to break. Parati ako nasisigawan ng instructor. But with practice, you can build confidence. Iba talaga ang tunog ng exhaust sa ilalim ng tubig. Parang mamamatay pero hindi naman.
Applicable naman for EFI and Carb. Halo naman yung group namin dati. May mga old school at later models.
thanks. i-correct ko na din ang driver ko.
