Results 1 to 13 of 13
    Feb 2006
    this happened years back pero i-share ko na din since nakita ko last week nung bumili ako parts dun, yung mekaniko na palpak ang top-overhaul sa kotse ko eh may i-ooverhaul nanaman na kotse. "carding" name nya if i remember it right, bald guy kaya easy to identify.
    eto experience ko sa kanya, loose compression kotse ko noon at sila may pinakamababa charge sa top-overhaul.. binantayan ko gawa nya kahit ala pa ko alam sa engines that time.
    1st mistake -- sinabit nya yung timing belt, pati yung bearing sa drier ng aircon ko, i questioned that, he replied "sir, matibay naman yan". after ng overhaul ayun may leak ang freon ko sa drier, he payed for it naman.
    2nd big mistake -- after 2 months nahalata ko nauubos ulet engine oil ko, i keep topping up every week. binalik ko sa kanya then he diagnosed na gasket daw sira, ayaw ng auto prens na free of charge kahit under warranty pa, 1st overhaul was 7k, 5k na lang daw to replace the gasket so inaway ko sila ng todo. after the fight i went to shell, again i had the engine overhauled, pagkatanggal ng piston, bigla nagtawanan mga mechanic ng shell. i found out na "carding" had installed the 3 piston rings in a perfect alignment so there was a straight gap.
    warning lang po sa mga taga las pinas or paranaque that carding is still the guy who does the overhaul jobs in auto prens alabang. and sa warranty ng auto prens? well masasabi ko lang po jan eh "nagsunog lang ako ng 7k sa kanila"
    Thanks for warning recklus, taga lp din ako and i just had my car serviced at pren months ago for a replacement of gasket ng valve cover, change oil and loosening ng timing belt because of the hissing sound at 1.5K rpm. ang sabi ng mekaniko (jek ang name) masyadong mahigpit ang timing belt. ayun pagkatapos ma service ayos ang idling sound even at that rpm. sira-ulo lang talaga ang honda dahil sila ang nagpalit ng timing belt ko on my last service sa kanila.
    akala ko pa naman matino ang serbisyo nila dyan. so saang shell mo siya dinala bro?
    Feb 2006
    shell almanza between goodyear and southmall bro. services nila dun mas mahal ng onti sa auto prens pero mas mura naman sa goodyear.
    Oct 2007
    Hello! i'm new to this forum, was surfing for some car info then i stumbled upon this site, nice place, lots of info.
    That's so unfortunate naman, my family has been bringing our cars to Prens ever since, sa southland pa dati yung shop nila. Nakikita ko nga yung "carding" sa alabang. Kay "Manny" kami nagpapagawa, wala pa naman kami na eexperience na problem kasi magaling talaga sya, kaso nasa Prens sa Sucat sya.
    Feb 2006
    may magagaling din naman talaga na mga mechanic sa auto prens. just watch out for that "carding", nakakasama pa ng loob yung management, to think na pati parts eh sa kanila ko binili tas pinagbabayad pa ulit ako.
    mga loko yun pinag praktisan siguro makina mo, dapat under warranty pa yun
    Dec 2008
    Yes, i agree to that, nag pa top overhaul na rin ako sa Prens last December 2008, Jec naman ung nag assist sa akin, lagi kasi napupundi ung 1 spark plugs ko, sabi nya may singaw daw ung gasket ko, so pina top over haul ko sa kanya, less than 4,000 ung binayaran ko. umaga ko un dinala sa kanya, tapos mga 5pm binalikan ko, sabi ok na daw, so kinuha ko na papunta sa office namin. Nung pauwi na ako, ayaw ng mag start, so iniwan ko nlng. Pina servican ko uli dun kay Jec, d nya pla chineck ung distributor bago niya ni release sa akin auto ko. after a week pumalya na naman, binalik ko ulit sa kanya, haggang sa nbwisit na ako, pinatinganan ko sa ibang mekaniko, tsaka sabi nya mahal daw ung singil sa akin ng prens compared sa kanya. 2k lang ung binayaran ko sa kanya kasama na ung gasket.
    Jul 2010
    Wow! muntik na ko nagpapalit ng clutch cable sa Prens. Buti na lang nakita ko tong thread na to... Kakatakot magtapon ng pera
    Ok naman experience ko dyan sa Prens, nasa mekaniko na lang talaga minsan. Si Carding alam ko matagal na wala na sa kanila, kung magpapagawa kayo dun hanapin niyo si Allan di pa siya pumapalya sakin. Maganda sa mga mekaniko yung mga by the book ang trabaho.
    Ok, I take this back. I just had my 97' corolla's carburetor overhauled last 2 weeks ago. Malakas na kasi sa gas 7km/L. After the job binalik ko kagad sa kanya, parang humina yung hatak, sabi niya drive drive ko muna. Lalong lumakas ang consumo ng gasolina. From Las Pinas back and fort to Imus Cavite Php500 ang consumo, tapos mausok saka parang hirap yung makina. Binalik ko ulit maitim yung spark plug, kelangan overhaul na daw yung kotse. Sinabi ko na di naman ganun yun bago niya overhaul yung carburetor. Matagal na daw ganun yun.
    Dinala ko dun sa Customer's Cradle, then I explain to them what happened. Binuksan ulit nila ulit yung Carburetor sa harap ko, baligtad pala yung kabit ng Jet: Primary - 160, Secondary - 101. After nila kabit, start the engine the put on the gas, lumabas lahat ng carbon sa tambutso. Mahirap daw mapagbaligtad yung size ng Jet.
    "Honest service is our business" isn't honest at all.
    Jul 2010
    Di pala dapat auto prens ang itawag sa shop....
    Aug 2009
    nagawa din ba sila ng electrical dun?
bad experience at Auto Prens Alabang
