Results 11 to 15 of 15
BANNED BANNED BANNED
- 3,790
November 25th, 2002 09:26 PM #11Pilo,
mali po ang pagkaka alam mo, fan ng radiator ng mga RWD ay pahigop ng radiator (nasa likod ito ng radiator sa pagitan ng engine diba).....so what it does is higopin ang cool air outside the car (galing sa harap ng oto's grille)....dadaan ang hangin sa fins ng radiator (thereby doing heat exchange at pinapalamig ang radiator)....pass thru the fan blades....and towards sa baba ng oto....
So kung ang ilalagay mo na aux fan ay nasa harap ng radiator...dapat papasok sa engine ang buga nito para tinutulungan nito ang existing mong radiator fans.
Things that would help a lot: radiator shrowd (dapat meron), use coolant:water mixture instead of plain water, get multi-bladed fans (radiator and auxiliary fans), thermal-type na radiator (di ko alam ang tawag dun talaga, pero uso ito sa mga pick-up na pagmainit ang hangin nagkakaroon ng reaction ang metal na ito sa radiator fan at kanyang "tini twist" pa ng konti ang mga blades para masmalakas ang higop ng air), high rpm motors ng auxiliary fans, metal blades ang aux fan para hindi matunaw.
my 2 cents
- 37
November 26th, 2002 12:19 PM #12Originally Posted by wildthing
December 20th, 2005 03:34 PM #13
December 20th, 2005 03:49 PM #14
it doesn't really matter if it pushes or pulls as long as you're moving the hot air away from the surface, so kung horizontally mounted ang radiator/condenser, the fan should help the air move upwards (natural flow ng air).
Push or pull, it makes no diff, wag lang push-pull sabay coz it tends to move the air too much and not remove the actual hot air on the surface of the fins.
- 3,790
December 21st, 2005 05:24 AM #15Originally Posted by acenie
just sharing... our car was puchased in Nov 2018 tapos last number issued was "7" so we...
1st LTO renewal after 3 yr registration
