Results 1 to 10 of 23
July 9th, 2015 11:23 AM #1
Need help! Especially sa mga naka Adventure. I'm about to replace my power steering fluid ang nalagay sa manual na ang dapat kong gamitin is ATF dextrone or dextrone II. Pero sa mga suking auto supply STP power steering fluid lang ang available. Is it ok to use the STF? Sabi nila universal daw un. Or kailangan ko talaga mag hanap ng ATF dextrone or dextrone II? TIA!
July 9th, 2015 11:38 AM #2
Just go with dexron II ATF. Marami naman yan sa mga ibang auto supply or hardware store sa mall.
July 9th, 2015 08:16 PM #4
Bigla ako naguluhan. Pumunta ako kanina sa casa tananong ko gamit nilang power steering fluid. Sabi nila yung pang power steering na daw. Di na daw sila nagamit ng ATF dextrone or dextrone II. Iniisip ko baka pwede na yung sa STF na power steering fluid.
- Apr 2012
- 3,469
- Aug 2012
- 2,767
July 9th, 2015 10:08 PM #6I will follow the owner's manual first and foremost.
If wala ka mahanap na Dexron or Dexron II, you can use Dexron III. Dexron III is generally backward compatible with Dexron. Below are ATF compatible with Dexron III.
Castrol Transmax Multivehicle ATF * P350+
Caltex Texamatic 1888 ATF
Petron ATF Premium
Top 1 MV ATF
Top 1 Super ATF DM-3
Top 1 Lifetime ATF (Dexron)
Valvoline MaxLife ATF
Petron ATF Premium
Top 1 MV ATF
July 9th, 2015 11:00 PM #8
- Apr 2012
- 3,469
July 9th, 2015 11:06 PM #9
- May 2011
- 227
July 9th, 2015 11:16 PM #10Buy mag1 psf mas maganda yan kesa sa atf for power steering mas smoother while turning
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
