Results 1 to 8 of 8
November 27th, 2006 03:14 PM #1
i inspected my transmission this morning and i noticed na may bubbles ung atf.
Ano po kaya ang cause nito mga sir?
TIA!
November 27th, 2006 03:23 PM #2
edit: oh your right sir afrasay.. why did i think it was the powersteering? my head's in the clouds today
November 27th, 2006 03:46 PM #3
i think nissan_eccs was refering to his tranny. let's wait for the auto tranny gurus replies.
November 27th, 2006 04:53 PM #4
i can name three reasons for the foaming :
1. overfilled with atf.
2. wrong type of atf used.
3. restricted or plugged transmission.
Zombie
- Aug 2006
- 728
November 27th, 2006 06:30 PM #5when was the last time you had a flush?
if you had, who did the flushing?
what's the color of the ATF?
is there some sort of plastic varnish in your dipstick?Last edited by torque2006; November 27th, 2006 at 06:31 PM. Reason: add'l questions
November 27th, 2006 08:07 PM #6
My bet is that you have over filled your tranny with atf. Have it drained immediately cause it would lead to serious problems with your a/t. Foaming or bubbling is one sign of an overfilled a/t.
November 27th, 2006 08:19 PM #7
Same speculation, overfilled tranny.
Drain right away.
I've updated the AT FAQ for your reference.
http://tsikot.yehey.com/forums/showthread.php?t=31796Last edited by theveed; November 27th, 2006 at 08:21 PM.
November 28th, 2006 09:54 AM #8
other cause of fluid aeration is low fluid, pump is pumping oil and air
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
