Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Nov 2006
    Mga tsikoteers,
    Question regarding sa white smoke..
    What if your car isn't overheating and no signs of blown head gasket (ie. Ung water sa rad nde bumubulwak if inistart ung makina, no oil in rad, no water in the engine.)
    Nangyari kasi to when I was driving sa Coastal.. nung una walang white smoke nung tumatakbo ung car. I was driving mga 30 mins na from Makati then suddenly sobrang white smoke ung lumalabas..
    As in parang trike ung car ko sa sobrang white smoke..
    Ika nga eh - "EAT MY DUST!!!"
    What do u think is ung problem?
    Oct 2004
    baka po clogged/blocked yung PCV (or crankcase breather)...
    Nov 2003
    have a compression check done and other tests to check if the engine is ok or not.
    Nov 2006
    Quote Originally Posted by speedyfix View Post
    Sir Speedyfix,
    How much nman kaya ung compression test?
    Regarding "other test" ano nman kaya un?
    Nov 2006
    Most likely head gasket and problema mo specially kung mitsubishi engine yan. Check your spark plugs, you'll see white residue baka sa dalawang cylinders adjacent to each other. If both cylinders then palyado rin yang kotse.
    Head gasket or cylinder head problem symptoms:
    1- Water boiling sa radiator
    2- White smoke sa exhaust
    3- Nau-ubusan ng coolant also will lead to overheat syempre
    4- palyado
    Kung glycol and gamit mong coolant, maa-amoy mo eto sa exhaust, sweet smell.
    If the above symptoms exist, your only choice is to remove cyl head and replace gasket hoping no damage sa cyl head. Pero kung warp or meron gouge ang head then you need to get the head milled.
    reply kung ayon ang problema para masabi ko kung ano ang side effect ng milled head.
    Nov 2006
    Quote Originally Posted by simpleng tao View Post
    4- palyado
    Dude,
    Salamat sa reply... btw.. Nissan Sentra Series 3 '95 un ride ko..
    1. Boiling water sa rad?!? Bka sa water reserve ung ibig mong sabhin... NO, is the answer.. nde sia boiling.. nde din sia nagbabawas pati ung rad..
    2. White smoke is positive. Start-up nandun sia.. Nwawala din nman sia ung nga lang pag-medyo matagal ung ride/biyahe mo minsan lumalabas sia minsan nde.. (Minsan means - some days not everyday.)
    3. Distilled pa lang ung nilalagay ko for the moment. Magcchange na din ako to coolant.. suggestion ni Otep... Nde sia nagbabawas ung water... ganun pa din..
    4. Palyado... Nde din smooth nman ung ride... medyo matagtag lang kasi lowered...
    Like i previously said.. No signs of blown head gasket (ie. Ung water sa rad nde bumubulwak if inistart ung makina, no oil in rad, no water in the engine.)
    Sep 2006
    brake fluid nagbabawas?
    Hello Im newbie here... got the some problem like jigga... nugn uan ganayn problem ko singaw sa cyl. head.. pero naayus nman ung problem kona ung .napalitan an ung gasket... no more bulwak ng coolant sa radiator..but one problem left still i get the same old problem ive emissioning a lot of white smoke... the only way i did after that working on that cynlinder head gasket is i shify from premium to unleaded.. is that shifting related to the white smoke? and ask na din ako kasi i got a problem... meron maingay dunsa may bandang belt ive check both bolt on alternator..pag tinatanggal ko maingay ap din.. is that ecky noisy sounds had got to do with the tensioner sa timing belt nya? thnks buddies buddies u hope a got a good reply sa forum .more power " Burn Rubber Your Soul"
    Nov 2006
    white smoke,..pero sabi mo hindi blown head gasket ang problem, maaring may leak ang combustion chamber,maaring valve train too tight (holding valve partially open),burned valve or seat,kaya ipacompression test mo na ang cotse mo habang maaga pa,if ito ang probs,ipa valve grind mo na kaagad or ipaadjust mo na ang valva train...
    Nov 2006
    Quote Originally Posted by dyeth28 View Post
    tungkol dun sa ecky noise ng tsikot mo,,sabi mo ginawa mo na lahat eh wala ka pa ring makitang problema,ang problema ng tsikot mo ay yung intake manifold gasket nya palitan mo kasi yan ang cause ng ingay,,ang gawin mo paandarin mo yung car mo at sa may bandang intake manifold buhusan mo ng tubig at mawawala yun or sprayan mo ng fuel injector cleaner,,at kung mag stall ang engine eh yun na,,intake manifold gasket lang..
    Nov 2006
    Quote Originally Posted by zonda View Post
    Dude, nde din eh..
    Siguro.. Papa-Compression check ko na nga ata talaga un..
    THe main question right now is how much will those test cost??
    Papi Denz salmat nag pala sa tricky tips. pinaadrae ko ugn engine then binuhusan ko ng 2big kahapon ung sa may bandang intake nya...nawala ung ingay..then kanina umaga start ko ulit...wala an tlaga ung ingay nya.galing theory ba tlaga un or experience lang.. and paps ask an din ako ung masyadong pagbuga ng white smoke ng pipie kow.is that got sumthing to dong pag shift kong premium to unleaded? kasi na work nman dati ung sa cyl gasket kow..and wala na din bumubulwak an 2big sa rad. ko if i starting the engine...may ida kaba kugn bat ganun nalang kalakas ang buga ng white smoke lalona pag umaatras ako...thnks and More POwer
    Sep 2006
    Quote Originally Posted by dennis powell View Post
    +1 ako dito. check for cracks na din
    kung papabayaan nya lang and babalewalain what could be the result mga maaring maapektuah?
    Nov 2006
    Jigga,
    Compression test will tell you cylinder pressure ng motor. The test can pinpoint low cyl pressure.
    White smoke is water in superheated state (steam) and the only place it can turn to steam is in the cylinder(s). Only source ng water sa cyl is from the cyl head.
    I still feel your problem is your head gasket. The only reason why you don't have most of the symptoms kasi early stage palang ang gasket leak. Small leak palang kaya hindi pa nababawasan ang rad water level. Though prolonging this may cause more problem warp head at baka itirik ka.
    Base ko lang sa experience.
    Quote Originally Posted by Jigga View Post
    Dude,
    Nov 2006
    Mga Tsikoteers,
    I'm sorry nde pa din ako nakakapag-compression test..
    Eto pa pla..
    When in traffic, ung temp gauge ko umaakyat.. from semi-half to 3/4... ni-rerev ko sia pero nde bumababa ung temp... bumababa lang sia kung tumatakbo na.. pero dahan dahan lang ung baba nia..
    Ni-rekta ko na nga ung aux fans para 2 ung naka-on.. pero ganun pa din.. umaangat pa din ung temp...
    I need to replace my thermoswtich like Otep said.. kasi nde nga sia nag-o-on kahit mataas na ung temp.. kaya ni-rekta ko..
    I'll also buy nga din pla ung thermostat like he said... feeling ko din talga mas maganda ung meron nun..
    My problem is palitan ko nga un.. ganun pa din.. ngaun nga lang.. laging nakabukas ung fan pero umaakyat pa din..
    Do you think i should have the waterpump replaced din.. just as a back-up.. baka kelangan na ding palitan.
    What do u think is the problem??
    I need to have some info before i get the compression test...
    Aug 2006
    Mga Tsikoteers,
    Eto pa pla..
    Bro pacheck-up mo na agad sa suking mechanic mo to analyze the problem..mahirap na baka mas lumalala pa ang problema ...preventive maintenance ika nga
    UU nga THE MORE na iniiwasan mo or pinapatagal ung problem the more na malaki ang madadamay.. magkakano manlang siguro yang compression test hindi namn cguro kabigatan sa bulsa??? magkano nga bah? ,, Ask an din ako kasi malapit na nman ako pa registro.. does thsi white smoke affect the result of your Emmision test? dbah black smoke lang ang sinisilip sa emmission test?? Salamat
    Sep 2005
    Last time nag inquire ako sa casa 500 pesos for compression test.
    yugn white smoke ba nakakaaffect din ba sa emmision test result? kasi mapapregistro ako this february eh nd kopa na reresolve ung problem ko d2 sa white smoke. ..Bak bumagsaksa emmison test pag may white smoke ?
Another White Smoke Problem..
