I have the same car and the same problem...halos maubos na yung pera ko sa kaka-check kung ano talaga problema...had my rad overhauled twice (top and bottom overhaul), spent a lot on coolants and labor, but in the end, 2 lang talaga main cause ng leak nya: 1) small bypass hose (sumisirit yung tubig pag umaandar na), pero hindi halata pag idle; 2) leaking water pump (konti lang, hindi rin masyado obvious). Bumili lang ako ng new water pump, kasi maingay na rin yung bearing, kaya ayun, nakita na may maliit na tagas
If I were you, palitan mo na rin water pump, tutal matagal na rin car mo, and besides it only costs 800 (GMB brand), although 900 nga lang yung labor
