Same problem with the Vitara now. Nauubos reserve pero puno ang radiator and hindi naman nag-ooverheat.
Recommendation ng Suzuki si overhaul/replace radiator and get a new radiator cap.
Kapag hindi pa daw naayos dun saka na lang mag-isip ng malalaki at mahal na piyesa.
Quote Originally Posted by Jigga View Post
feeling ko nga dude.. ung water pump ung problem.. halos maubos na din ung pera ko dun sa auto ko eh..
900 ung labor mo? mahal nman..
cge pa-check ko muna ung waterpump nia.. if olats talaga.. its time to change it..
salamat sa replies..
ill have it checked tomorrow..
Mga sirs,
I found the problem kung why nauubos ung water sa rad and reserve ko... There was a leak dun sa malapit sa water pump..
When i asked the mechanic na tignan ung water pump he said na walang prblem ung water pump and yung connection nun hoses ung may problema..
I don't know kung ano ung tawag dun pero sabi nia "bypass" ?!?!?
sia ung connection ng mga hoses galing dun sa water pump...
nwei.. sbrang rusted na talga sia.. kinakain na sia ng kalawang..
so i had it replaced. it cost 1450 ung part and 1000 for the labor...
so un.. ok na dehins na sia overheat. buti na lang.. hehehe
salamat sa lahat ng replies.. thanks!
