Results 1 to 12 of 12
    I was driving yesterday when suddenly I drove in a street of no turning back w/ almost knee high FLOOD!
    I know I can get over the nasty flood but I felt some weird action with my ESi as I pass by.
    Every 20KM the dragging exist simultenously.Even if I change gear the dragging stops for a second and then it comes back.Litterally I have no idea about this problem, so.. I jump out in a small talyer near mindanao avenue and look for a mechanic..
    The mechanic told me that maybe the clutch was dripped in the water flood and still wet inside.
    The only solution is to change lining and clutch disc w/c will cost me 12T inclusive with their labor..
    If this is true,is there any alternate solution that I can do to make it back to normal?
    Are you still experiencing the dragging issue? Baka hindi nama clutch yan. Did the problem started only after driving through the flood? Baka naman sa brakes lang yan. Better get a second opinion from another mechanic.
    I agree, ask from several shops and their mechanics.
    Also whatever you do, DON'T GO TO Rapide!
    kahapon sir sobra sobra yung pag da-drag nya..I was planning pa nga to go to west ave to buy a 4 set of new tires.Nakauwi ako ng bahay na 20-40km lang takbo ko..talagang malala.
    Anyway isa pa lang pinagtanungan ko kahapon..siguro dapat ipagtanong ko pa sa iba.
    Salamat sa payo,Good AM,GOD bless.
    ok na po yung problema..My 4 tires are diagnosed by honda that are oblongs.Ibought 4 brand new tires yesterday and it's done.Grabe yung nagbenta sa akin neto masyado sinistema yung sasakyan..ang dami ko ng pinalitan na pyesa. /swt Thanks sa mga payo.
    Nov 2003
    kung oblong yung gulong mo malamang they were that way even before you went through the flood. i don't see what the connection is.
another big problem!
